Does the ZF 5 fit?
Old Mar 12, 2017 | 04:09 PM
F-250 restorer's Avatar
F-250 restorer
Does the ZF 5 fit?
Does it fit in the dent trans tunnel?
I know it bolts up to the block, etc., but no one ever mentions whether they needed to do sheet metal work on the trans tunnel/floor.
I could splice in the tunnel of a efi truck, but would rather avoid it, unless absolutely needed.
Thanks for the replies.
Old Mar 12, 2017 | 10:56 PM
CanadianBuzzard's Avatar
CanadianBuzzard
My experience is that it requires extensive tunnel modifications. Someone may be able to speak up about whether it can be made to fit with less clearance but I wanted enough clearance to be able to remove the transmission without pulling the motor. To accommodate that I had to rework the tunnel and make a whole new cover.
Old Mar 12, 2017 | 11:32 PM
F-250 restorer
I have a 75 f250. I think I will cut the entire trans tunnel out of an efi year truck, and transplant it into mine. I know it will ride up higher on the firewall, but hopefully my heater won't be in the way.
Brandon England
18
Dec 26, 2018 03:01 PM
Kalve
Apr 12, 2010 10:24 AM
jnehring
Sep 7, 2007 12:53 PM
tyzsdad
Bronco II
Aug 10, 2004 11:09 PM
FORDWRENCHHEAD
Jan 7, 2003 06:17 PM
