Adding amp to sound system?
Old Mar 12, 2017 | 12:04 PM
Whit Rush's Avatar
Whit Rush
I planning on adding an amp and sub. Where is the easiest place to tap into the speaker wires? I'm not wanting to tear the dash apart if at all possible.
Thanks,
Whit Rush
Old Mar 12, 2017 | 01:03 PM
System's Avatar
System
Prolocutor
The factory amp and sub is right behind the rear seat. You can tap the wires feeding your factory sub to feed your sub amp. That's what I did.
Old Mar 12, 2017 | 07:34 PM
Whit Rush's Avatar
Whit Rush
Sorry, not enough info. I have the sync3 but no amp subwoofer. It is a f350 xlt super crew.
Old Mar 12, 2017 | 07:38 PM
System's Avatar
System
Prolocutor
You could tap the rear door speaker feeds for signal then. They run in the B pillar.
Old Mar 12, 2017 | 07:47 PM
Whit Rush's Avatar
Whit Rush
****, still not enough info. In addition to the sub, i'm adding a amp to the rest of the speaks. So i need access to all the feeds.
Old Mar 12, 2017 | 08:01 PM
REPO.'s Avatar
REPO.
Pull the dash apart and locate the speaker wires you require. There is no fool-proof easy way to access them all without doing some work.
Old Mar 14, 2017 | 10:00 AM
bluewaveaudio's Avatar
bluewaveaudio
Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
this is all you need problem solved
Old Mar 14, 2017 | 10:05 AM
System's Avatar
System
Prolocutor
Great find but it's for the Sony premium system only which the OP doesn't have.
Old Mar 14, 2017 | 10:06 AM
bluewaveaudio
**** your right, behind the factory radio it has a full range output, haven't done a non sony yet but have one coming in next weeek
Old Mar 14, 2017 | 10:15 AM
System's Avatar
System
Prolocutor
Still a great find! Reps sent...
I posted it in the other audio thread too. Looks like they beat RF and Kenwood to market on this.
Old Mar 14, 2017 | 01:29 PM
bluewaveaudio
Thank you Karl, I should have used one in my own truck and I may still end up doing it but Ive done 2 this week with pretty awesome results. Sure makes the job easier for sure.
Old Mar 14, 2017 | 01:31 PM
System's Avatar
System
Prolocutor
If you were to go that route, you'd really be better off going with the RF DSR-1. Does the same thing, is $50 cheaper, and can be adjusted on the fly with BT. Only catch is, it's not out yet.
Rockford Fosgate® -
Old Mar 14, 2017 | 01:34 PM
bluewaveaudio
Rockford Fosgate® -
I haven't been real happy with the rockford 360-1-2-3 witch ever model they are up to, the Helix DSP pro processors with 10 channels is really clean, fairly simple to use and just works, thats the only processor I will sell and stand behind right now, If I do the Pac piece ill run RCA cables to the helix and then from there to the amps, right now I cut the outputs from the stock amp and ran them in to the helix speaker level inputs, to sum high and low together
Old Mar 14, 2017 | 01:40 PM
System's Avatar
System
Prolocutor
The good thing on the 17's is the easy access to everything behind the seat. So, changing things in the future as they come out or as your needs change, is a lot easier!
Old Mar 17, 2017 | 01:33 PM
Whit Rush's Avatar
Whit Rush
Anybody have a wiring diagram for sync3? Specifically 2017 F350xlt non-sony.
J78
Oct 12, 2018 10:26 PM
superdutyon37s
6.7L Power Stroke Diesel
Sep 1, 2015 09:42 AM
skohler
Jul 14, 2005 12:33 PM
k80kid
2004 - 2008 F150
47
Jan 13, 2005 07:54 AM
Frdbuy8589
Aug 23, 2004 03:43 PM
