reverse lights and dome light???????
Old Dec 10, 2001 | 04:52 PM
phatpharm85's Avatar
phatpharm85
im having a problem with my reverse lights they dont want to work?? yes i replaced them with new ones. same true for the dome light. the fuse that's labled for the dome light cuts off my constant power for the radio and is fine. the fuse for the reverse lights is fine as that controls the blinkers also. does any one know if there is another fuse panel? i looked good in the engine compartment and couldnt find it. i pulled the dome light apart and made sure everything is still connected. my warning buzzer dosent work either. this all leads to one thing bad fuse or bad main connection some were. i also have problems with my wipers becomming intermitant but i narrowed that down to the switch itself.
thanks for reading my problems
jon
Old Dec 10, 2001 | 06:24 PM
stover007's Avatar
stover007
Post reverse lights and dome light???????
