I drive a 2004 f350 with 120,000 mile on it. When I got off work today and started it up I noticed it was kinda idling rough which it's never done. As I pulled away the truck began to shake but I have check engine light. When I got home, I got out and could smell sulfur. What could it be? I was thinking bad cat but I don't think that would cause the shaking, would it? Or maybe bad plugs but then wouldn't my truck through a code? Please let me know what you think ASAP, this is my daily and I have work in the morning.
If the truck is an OBD1 calibration, it's ability to self-diagnose is limited and it may not set any codes unless the misfire is very severe. You'd have to go in and look at individual cylinder misfire counts with a scan tool to see which cylinder(s) is the source of the problem.
I meant to say it has no check engine light. It ended up being a bad spark plug... well actually they were all pretty bad. Problem solved. I guess my dad didn't do much maintenance on the truck before I bought it.
sulfur smell is classic sign of a bad cat, and running rich will expedite that process.
It's also a characteristic of a cat that cannot handle the load of raw fuel that is being dumped into it by a misfiring cylinder. Of course, if the misfire is left unrepaired, the cat will be permanently damaged.
