Sway Bar Bushing - Help
Old Apr 10, 2017 | 09:03 AM
Rick1025's Avatar
Rick1025
WorldCommander, The photo you posted looks like a dana 60 front axle from a 4WD.Is that true? Is this a Quigley?I have to do mine this week.I got the bushings from Energy Suspension,but as told the Moog bushings were poly also.The steel sleeve needs to come out either way. Use a sawzall or a dremel to cut thru,and then collapse the rest with a chisel.Energy Suspension says to lube the new bushings to install them.
BillyBob69
Jun 11, 2019 11:45 AM
jerseymike
May 5, 2016 11:36 PM
eyewall
Oct 24, 2015 07:01 PM
DieselBeast01
Jan 19, 2009 01:33 PM
MadCowRacer
Nov 22, 2007 10:54 PM
