Thanks Bill would it be safe to assume that the 330 ft would have the larger crank snout like the 391 ft I'm doing a swap from the 70 to a f800 with power steering and need to change crank balancer. Again thanks for the decoding of the VIN tag
1968/78 330 2V Medium Duty uses the 360 2V FE crank, 330 2V Heavy Duty & 361 2V FT crank is different. 391 4V crank is different again.
