Received my first FSA (Field Service Action) on my Ford Owners page. Looks like I need to schedule my truck in for the new Transmission Cooler Line repair.
FSA Title: TRANSMISSION FLUID COOLER TUBES REPAIR
Field Service Action Number: 17B03
If you haven't registered on the site, do so, lots of good info there.
Called my dealer for more info, FSA says less than 1% of vehicles affected. Instructions are to inspect, and if it's not leaking install a new bolt and washers. If leaking line set is to be replaced.
according to the my build date I should have it as well, but it is not on my owners site
Is there vin or date range? My truck is at the dealer now and I'd like them to check if I also have it.
Sitting at dealer now waiting on the truck, been following the post here about the lines coating the bottom of people's trucks with fluid and have been keeping a close eye on them. Line have stayed dry so far, here's hoping for just a bolt and washer and a quick fix.
