Audio build part 1, SOUND DEADENING!!
I couldn't stand the flimsy doors on our new 2017s, Also after driving in the rain Saturday the rear doors were still dripping water Monday at lunch time. So I said screw it, Im doing my audio build over the next two weeks so I said lets do this early.
Each door got a layer of Second Skins Damplifier Pro on the inside and outside skin.
Spray glue was applied over the Damplifier and Overkill Pro Closed cell foam was glued on to the door skins,
spray glue was applied to the Overkill and luxury liner was installed over that.
Door Panels
Factory diaper pulled off,
a layer of Damplifier Pro
spray glue and Overkill Pro was glued on.
The difference is day and night. Ive taken 2 people for a ride in the truck and both of them have booked appointments to get their 2017s done.
I have to do the floor and back walls next but that will come when I pull the interior out.
drew a fine line around outside plastic so I knew where to stay inside of panel
pulled drivers side panel off
inside factory front door, 1 piece of sound deadener and seam sealer
layer of Damplifier pro going on inside skin
wrapped the bracing in the door
Overkill foam glued on
inside skin wrapped with damplifier pro
diaper pulled off factory door panel
damplifier pro added to door panel
glued overkill foam on door panel
front door back together and nothing is visible
wanted to show the amount of moisture in the rear doors
Steven-
Door Panels
Steven-
If you want to buy second skin stuff sign up for their emails list now. Every holiday they have been offering 20% off coupons.
Did all of that fit nicely in the doors? I tried with my old chevy to get the luxury liner pro to fit but the door skin wouldn't fit back on due to the thickness of the luxury liner. Had to go to a smaller ccf and then some 1/8" think mlv over that. I prefer the industrial velcro over spray glue that way it is super easy to remove and never sticky. But both work!
2 hybrid audio clarius 10s in a down fire ported box. I'll start the audio build thread shortly or edit this one. The whole interior is out and just started deadening and running wires
Automotive doors are designed to take in water and drain out through the bottom, its been that way as long as I can remember
My buddy in louisiana at Fox Accustics built me a box for 2 10'' subs, down firing in a ported box, bed lined and the ford logo engraved in the front of the box. amps will be going behind the back seat and on the shelf
