Escape purchase advice
I'd like to spend $15,000 or less on a low-mileage rig, hopefully somewhere in the 2011-2014 era.
I'd like to get a 4 cyl for mpg reasons. It also needs to be AWD/4WD.
I plan to own this vehicle for a long time (ie until its 10+ years old).
I would like to hear whether any of the 2011-2014 years/models should be avoided. I have to admit, I'm a little leary of the turbo units (reliability/repair costs), but I'm open to all input.
Thanks.
avoid the AWD because you probably don't need it. And because it's hard to work on and expensive.
Avoid the 4cyl becaus the V6 is an amazing engine- tons of power and actually exciting. Lots of torque steer
My wife gets over 20mpg and she never leaves the city. Probably 26-28 highway.
The hybrids are and will always be more reliable than the ICE escape. Not only do they NEVER have transmission problems, they are literally the only hybrid right now that are not susceptible to degradation. Most have 100k warranties on them from the factory still. The insurance cost is literally no different. There has been only two recalls for the hybrid. One, the MECS pump under the front bumper than you can replace by yourself for $25 and 1 hour. The other is a cooling fan in the battery compartment that fails, costs $30 and can be replaced in 15 minutes. ICE escapes are riddled with tons of issues, including the common transmission band breakage issue. The hybrid doesn't even have a band to fail.
Again, wrong. The only thing that commonly fails on an AWD hybrid system is the cracking of the tone rings on the CV shafts that doesn't even really occur that often. $5 and an afternoon to fix. FOREVER.
My wife gets over 20mpg and she never leaves the city. Probably 26-28 highway.No escape V6 engine ever saw a day over 18 MPG. This is a complete and utter lie. The hybrid puts out an equal amount of torque and HP, yet gets 25-28 MPG.
2nd, it is common knowledge that hybrid vehicles have higher insurances costs. They are less common and higher cost to replace/repair. Same reason a Chevy Volt (electric) has higher insurance than a Chevy Spark (gasoline).
Lastly, my wife's Escape V6 gets over 25 mpg highway ... whether you like it or not- it is truth. I've measured it myself. It'll actually break 30mpg if the speed is kept low (I think 55-60mph is what I found).
No lies here fella.
No lies here fella.
It's funny you make the comparison between the Volt and Spark, not only because those cars are absolutely nothing alike and incomparable, but one is a compact electric and the other a "city" car, which in terms of size and price is the bottom basement. A better comparison would be a Cruze. You effectively attempted to compare a $10k vehicle to a $40k one.
The worst part about what you claimed above is that you used the Volt as a comparison. I currently own a Volt, that I replaced a Cruze with.
The cars share the same model year and have had the same insurance provider. I want you to take a wild guess as to how much my insurance "increased" when I made the change. Yeah, it went down $4 on a six month term.
Lastly, it just so happens that my wife's vehicle is a 2007 Escape 4x4 with the 3.0L. There was NEVER a day that this vehicle has EVER seen over 18 MPG. Hell, even the goverment rated it at 20 city, 24 highway. That, and the damn garbage transmission had been replaced under warranty three separate times. But wait, we're not done yet.
My previous job (2006) required me to use a 2005 escape hybrid as my transportation from aircraft to aircraft in a storage facility. This vehicle idled for thousands of hours, was subject to hundreds upon thousands of stop/starts and high heat. It never once failed me and always returned 26-28 MPG.
I haven't spent a lot of time here in the Escape forum, but it seems like you are "that guy..." every forum has one.. what a shame.
Anyway ill return quickly to debunk the myths you just posted. See you soon.
https://www.ford-trucks.com/forums/1...ghway-mpg.html
My 2010 Ford Escape V6 obtained over 23 and over 26mpg on a highway trip. This was during the 70+ mph portions. Upon driving slower, it obtained over 28mpg.
Just because your 4x4 Escape never cracks 20mpg doesn't mean its true of them all.
I'll await your apology for (literally) calling me a liar.
your wife's car never exceeded 18mpg even though the EPA ratings are 20 and 24 (your words, not mine)
exhibit B.2: Copied from Fuelly.com "Based on data from 12 vehicles, 461 fuel-ups and 111,427 miles of driving, the 2007 Ford Escape gets a combined Avg MPG of 19.57 with a 0.31 MPG margin of error."
Maybe there's something wrong with your Escape. Since you are on the low end of the curve.
https://www.nerdwallet.com/blog/insu...s-hybrids-gas/
Exhibit C.2: "http://blog.esurance.com/why-car-ins...ds-costs-more/
Conclusion- Insurance costs on hybrids is measurably higher.
Again, another example of you believing your personal experience is indicative of all others.
you said "It's funny you make the comparison between the Volt and Spark, not only because those cars are absolutely nothing alike and incomparable, but one is a compact electric and the other a "city" car, which in terms of size and price is the bottom basement. A better comparison would be a Cruze. You effectively attempted to compare a $10k vehicle to a $40k one."
However, a quick search on Kelley blue Book indicates a Spark at $6619 and and equivalent Volt at $11,500. (Both were searched the same: White, 60K miles, 2014 model year, standard equipment package, "very good" condition.)
$6619 is very different from $11K, but certainly not as bad as your example of $10,000 & $40,000.
