1987 F150 Leaf Spring Help
Old Mar 2, 2017 | 08:43 AM
Bib's Avatar
Bib
Need some input before I go any further….
Wanting to remove 2” inch block from rear leafs. Truck is in the air with rear axle supported as shown (not shown are the two floor stand helping hands under the rear axle). Made the assumption that there is no pressure on the leaf springs with this set up and went to cutting off the u-bolts. Well, first one I cut exploded with a BANG. Damn near scared me to death…what am I over looking?
Thanks,
Bib
Old Mar 2, 2017 | 08:54 AM
Onions.n.Butter's Avatar
Onions.n.Butter
That's normal for them to scare the crap out of you. Lots of tension on the u-bolts themselves. You're completely fine as long as your jackstands have a bit of pressure on them.
Old Mar 2, 2017 | 09:00 AM
Bib's Avatar
Bib
Excellent....that was one hell of a noise when it popped for sure!
Thanks,
Bib
Old Mar 2, 2017 | 03:55 PM
GoinBoarding's Avatar
GoinBoarding
Yep the u bolts are under a lot of tension, as they are stretched when torqued to specification.
Old Mar 2, 2017 | 08:45 PM
88n94's Avatar
88n94
Generally when working with the rear axle housing it's best to block both sides of the frame. With hefty wood blocks rather than jack stands. Get it blocked and stand off to the side and shake the truck to make sure it is secure.
I'm a little late to the party, I hope it works out for you safely.
Old Mar 3, 2017 | 05:19 AM
Bib's Avatar
Bib
Thanks all. I will report back on Saturday.
Old Mar 5, 2017 | 05:37 AM
Bib's Avatar
Bib
Got 'em done. Loud bangs and all. As mentioned by all, just minor movement. Still not one of my favorite jobs!
Check out the bushing...yikes.
Old Mar 7, 2017 | 08:26 PM
brooksville george's Avatar
brooksville george
never thought of supporting the axle like that but it looks like it worked, I have the same lift good lift for the cheap investment
Old Mar 8, 2017 | 05:00 AM
Bib's Avatar
Bib
Came to me in what of those "what if" moments...glad it worked as well as it did.
As for the lift, love it. Got too old to be on my back all the time.
mebe2k
30
Dec 22, 2015 01:02 PM
93F150&69Stang
Nov 28, 2015 01:31 PM
Headviking
Apr 29, 2009 12:06 AM
biggcountry235
May 3, 2007 09:47 AM
073f100
Jan 20, 2001 08:39 PM
