antenna mount options
Old Feb 28, 2017 | 04:42 PM
jimzpsd's Avatar
jimzpsd
I normally run three antennas on my old truck, all three being magnetic mounts, have any of you guys switched to something for an aluminum mount?
Old Feb 28, 2017 | 05:12 PM
lkbrow1's Avatar
lkbrow1
I made a T shaped piece of metal that has a flat square top and a blade underneath it all of 1/4 steel. The blade fits in the square hole on the top rail of the truck bed just behind the driver. It is secured by a bolt through the hole on the inside of the bed. Then on the flat top piece of metal is where I mount a fiberglass whip. The cable is routed inside the wall of the bed to underneath the cab and through an existing hole in the cab under the carpet to the front of the cab. This has work on all of my trucks.
Old Feb 28, 2017 | 07:02 PM
jimzpsd's Avatar
jimzpsd
Nice, thank you. My three need to be spaced apart from each other for proper tuning, I was thinking about a headache rack.
littleapple
Sep 1, 2024 03:27 PM
cavman2112
Jun 8, 2017 11:51 AM
rollincoal
Jan 2, 2009 12:35 PM
WXboy
Nov 10, 2003 07:01 AM
blue 79
Alberta Chapter
Jan 11, 2003 08:20 PM
