Sponsored by: Real Truck
Did I do damage???
Old Feb 28, 2017 | 03:28 PM
Nathan McIntosh's Avatar
Nathan McIntosh
Did I do damage???
How badly can I damage my braking system, calipers, pads, rotors, if a speed sensor goes??
story goes, just got this 2011 f350 6.2L just last week, and today as I was driving to the dealership to complain about my four-wheel-drive not working in auto mode I noticed that I was burning a lot of fuel about halfway into town . As I approached town, Check system light came on, so I got out of the truck and all four rotor are smoking!
Needless to say it is at the dealership, and they said they are going to take care of it, and the auto lock on the 4x4
Old Feb 28, 2017 | 05:45 PM
dpilot83's Avatar
dpilot83
I am not aware of any way that a speed sensor can cause the brakes to be applied. That seems very strange. I'd like to know what they say about it if you get a detailed explanation.
Old Feb 28, 2017 | 06:21 PM
fordman19762003's Avatar
fordman19762003
If the rotors were hot enough that they were smoking you could be looking at ruined brake pads, warped rotors, along with whatever caused the brakes to drag. Also keep in mind that the heat generated could damage the wheel seals in the axles if it got hot enough for a long enough time.
Old Feb 28, 2017 | 06:39 PM
Desert Don's Avatar
Desert Don
I didn't know the 350 had an "auto" mode for 4 wheel drive........
It should be just 2H, 4H, or 4L....that's it, unless it has the manual shift transfer case, then it would be 2H, 4H, N, 4L.
Old Feb 28, 2017 | 06:46 PM
82_F100_300Six's Avatar
82_F100_300Six
I too am confused by this.
Old Feb 28, 2017 | 06:52 PM
scraprat's Avatar
scraprat
Top Answer: 5
Hopefully the rotors didn't get to hot to effect the wheel bearings/ seals.
Old Feb 28, 2017 | 07:00 PM
Nathan McIntosh
The AUTO setting on the wheel hub. the vacuum isn't working, and now i am sure along with some other things.
I will update this post tomorrow when I know more.
as for the smoking, it has been raining out so i am hoping it was mostly steam, but that is probably wishful thinking.
I will get them to check the seals, and whatever else you guys believe could have been damage, man i still reek of brake pads
olywo777
May 3, 2015 10:29 AM
renoduckman
Apr 27, 2009 12:31 PM
skoveng
Apr 19, 2009 03:56 PM
suvlover1
Jul 7, 2008 10:23 PM
bradk
May 4, 2006 05:23 PM
