Lacquer/Enamel/Urthane paints?
Not have a clue when it comes to selecting types of paint? Looking at TCP Color Library found the Wimbledon White, and Sahara Beige comes in Acrylic Enamel, Acrylic Urethane, or Acrylic Lacquer and curious if one type is preferred over the other, and do they require a hardener, and reducer?
Lacquer.....
This was the oem standard up until the mid 60's......although Porsche, etc. continued with lacquer for many years after IIRR.....lacquer looks beautiful and is easy to repair but, it is very sift and scratches easy (even the acrylic)...... makes an excellent touch-up paint, but would not use this for any vehicle today...many states won't even allow you to receive it.
Enamels......the oem paint beginning in the mid 60's up through the 80's......a very good durable paint, looks nice but doesn't finish as nice as lacquer
Urethane......the best of the best....finishes as nice as lacquer, easy to repair, but is a very hard but flexible paint, meaning it doesn't scratch easily like lacquer but looks every bit of it!
All paints require reducer & hardner.....this should all be purchased at your local auto paint supplier IMHO......the reducer type is matched not only to the type/brand of paint but temp & humidity....hardners.....the paints today have Isocyianates....these are extremely deadly toxins that will absolutely damage your lungs, central nervous systems, kidneys, liver, bladder, etc.......there is no "good Exposure" as even one time inhalation, injestion, absorbsion or injection (via a cut) is more than enough to cause immediate illness (permanent) or long term...cancer.
Lacquer.....
Again, I thank you, very helpful!!
This was my previous truck...it was repainted by Ford (courtesy) about 10 years befor this pic was taken......this is PPG urethane basecoat/clearcoat
https://cimg9.ibsrv.net/gimg/www.for...904a3e3a77.jpg
https://cimg4.ibsrv.net/gimg/www.for...8b4c9711d0.jpg
Not the best pic, but this is my mustang......it is single stage PPG (back when it was known as Ditzler)....the paint is 30 years old and most painters don't realize it!
Again, I be thanking U!!
