Lifting a 2wd?
Old Feb 27, 2017 | 03:22 PM
Rjustinpalmer's Avatar
Rjustinpalmer
4wd Low
Lifting a 2wd?
I just got a new 2017 f250 and decided on 2wd for the sake of simplicity, but shopping around for lift kits, it looks like everybody makes kits for the 4x4 only! Will these work on a 4x2? Can I even lift my truck?
Old Feb 27, 2017 | 03:40 PM
oklarado's Avatar
oklarado
Good luck with that front end. They do make kits but it'll be like a pre-runner set-up.
Old Feb 27, 2017 | 04:17 PM
Frantz's Avatar
Frantz
Oklarado is correct that the front end is totally different. It's not gonna be easy and I don't think you'll be that satisfied. Reminds me a of a guy who tried to save a buck by skipping on the Sirrus radio =P
Old Feb 27, 2017 | 04:22 PM
oklarado's Avatar
oklarado
Lol, but they are sending me some little doo-hickey that will supposedly work. Yes I would've gladly paid the 185.00 if I knew then what I know now.
Old Feb 27, 2017 | 04:31 PM
Frantz's Avatar
Frantz
the 2wd is still twin I beam, which was old technology on my '79. It has pros and cons, but it is robust!
Old Feb 28, 2017 | 01:17 AM
Rjustinpalmer
4wd Low
I don't t necessarily need anything crazy, just like a leveling kit, could I do blocks?
Old Feb 28, 2017 | 05:08 AM
Frantz's Avatar
Frantz
It would take alot of blocks I'd think. I'm no lifting expert, but the twin I beam would require both the outside and inside to be blocked in order to keep the geometry right. On the twin I beam the wheels don't actually go up and down, the follow an arc from the inside point of each I beam. The beams cross in order to give a longer arc. The idea is to be strong like solid axle but provide the better ride of independent front suspension.
You might want to check out the older truck forums and see what they do, back in the day Ford did yous the twin I beam on 4x4 as well.
Old Mar 18, 2017 | 08:43 PM
Rjustinpalmer
4wd Low
Any reason why this kit wouldn't work? It's for a 2010 instead of a 2017 but it seems like it would work.
6 Performance System w/ Stealth Shocks - 2008-10 Ford F250 2WD w/ V8 Gas
Old Mar 19, 2017 | 12:08 PM
Frantz's Avatar
Frantz
That's the principle of what you'd want! I wouldn't think going back 2 generations would line up though. Maybe call them and see if they'd be willing to fab you one for the new chassis.
Old Mar 19, 2017 | 12:17 PM
Rjustinpalmer
4wd Low
I sent them an email, hopefully they'll get back to me by Monday and we can work something out.
biebeda1
Jun 7, 2018 09:32 PM
2012f2506.2
Jun 3, 2017 06:07 AM
Issach21
Jun 17, 2016 10:20 AM
eric95
1983 - 2012 Ranger & B-Series
Oct 26, 2004 03:49 AM
Black88GT
May 24, 2004 10:56 PM
