Speedo question, Maybe Gary
Old Feb 26, 2017 | 07:04 PM
bcamill's Avatar
bcamill
My speedometer is reading 18% higher than I am traveling. For example, when it reads 55, I am, traveling at 45. I have 18 teeth on the cable. How many teeth should I have for an accurate reading? Thnaks.
Old Feb 26, 2017 | 07:17 PM
FuzzFace2's Avatar
FuzzFace2
It might also help to know what year truck you have, rear gear the truck has, the rear tire size on the truck and the trany the truck has.
Dave ----
Old Feb 26, 2017 | 08:41 PM
Gary Lewis's Avatar
Gary Lewis
55 divided by 45 is 1.22222. Taking 1.2222 times 18 gives 22, so you need a 22-toothed gear. Unfortunately, as shown here, that's not a stock Ford gear. But, I have seen them at places like Summit.
But, a readily-available 21 would get you close.
Old Feb 27, 2017 | 07:19 AM
Cg willie Willie's Avatar
Cg willie Willie
I would be interested to know what size wheels and tires you have
bcamill's Avatar
bcamill
Thanks Gary. Now I understand the math. I bet it is a 21 as the truck is all original except for the trans rebuild. I was looking at speedometer while passing the local radara, so I could be off a mile or two and that is if those are calibrated correctly.
Old Feb 27, 2017 | 07:36 AM
Gary Lewis's Avatar
Gary Lewis
Yes, it is simple math. And if the truck is stock then a stock gear is likely to work.
As for tires, gears, etc you can figure out the stock speedo gear here: Speedometer Driven Gears - ???Gary's Garagemahal
Old Feb 27, 2017 | 08:50 AM
bcamill's Avatar
bcamill
The truck is 100% stock. I have the original 15 inch wheels that came with it.
Old Feb 27, 2017 | 04:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
22 tooth gear will read too fast, so will a 21 tooth gear.
The nylon DRIVEN gears at the end of the cable are approx. 5 MPH difference, so the OP needs a 20T gear to slow the speedo down from 55 to 45 MPH
The same 16 thru 21 tooth nylon DRIVEN gears have been used from 1960, are available from Ford and auto parts stores.
Old Feb 27, 2017 | 06:50 PM
Gary Lewis's Avatar
Gary Lewis
Bill - You need some qualifier in there as the same gear change that would make a 5 MPH difference at 30 MPH would make a 10 MPH difference at 60 and a 15 MPH difference at 90 MPH.
Old Feb 28, 2017 | 12:57 PM
1986F150six's Avatar
1986F150six
What tire size? 235/75 X 15, 215/75 X 15, 215/70 X 15?
Old Feb 28, 2017 | 06:52 PM
Gary Lewis's Avatar
Gary Lewis
Just FYI, here's a table for the driven gears for this particular situation. It is just simple math. The yellow represents the information given, that at 45 MPH actual the speedo is reading 55 MPH.
Old Feb 28, 2017 | 11:27 PM
Cienega32's Avatar
Cienega32
That chart sure is helpful [motivation wise]. I have a speedo discrepancy myself that I've been meaning to address. Maybe this will get me to actually check it out...
Old Mar 6, 2017 | 07:33 AM
bcamill's Avatar
bcamill
Thanks Gary, I am spot on now. I just need to remember that it is correct when reading it.
Old Mar 6, 2017 | 07:43 AM
Gary Lewis's Avatar
Gary Lewis
What gear did you use?
Old Mar 6, 2017 | 10:46 AM
bcamill's Avatar
bcamill
21 was the one
