pulled fuel lines (and motor) from a '95 to drop in a '52.
do i need to replace the o-rings in the fittings (that require a special tool) at the motor, tank, and filter? i don't see them listed separately at rockauto.
or just push 'em all back together and not worry about it?
You should be able to replace those O-rings with standard Viton O-rings of the right size. Rockauto has them in 5/16" and 3/8" sizes. I'm sure other sources have other sizes.
is viton a brand or a material?
assume i need something special for fuel use (i.e. not just normal o-rings from ace hardware)?
thanks.
Viton is a DuPont trade name for a flouro-elastomer used in a lot of O-ring applications where resistance to petrochemicals and wide temperature range are needed. Check your local auto parts store.
Don't get the O-rings from the hardware store designed for household plumbing. They will disintegrate when exposed to gasoline, and can clog up your fuel system.
thanks…
…and per your sig — in addition to this old truck i'm also building up a '96 Bontrager TiLite.
hmmm... no luck finding them yet. can't seem to find them on rockauto (search for 'viton' just brings up mercedes vito). advancedauto sells viton o-rings in those sizes, but all of the reviews say they will definitely not fit the fuel rail line fittings, despite the size:
I just coat the factory o-rings with vaseline and re-install...I've never had one leak.
That should work too, if the lines have not been subject to excessive heat. Just slip them together and cycle the key on/off a few times to pressurize the lines. Then look for leaks at the joints.
They have them labeled by OD, not ID. They are 1/16th thick so you are looking for 5/16th by 7/16th and 3/8th by 1/2 inch for the smaller and bigger when you search online. My Ace had Viton for the smaller and I stopped by a friend's truck repair and got some of the larger. 88 F-250 was getting some bubbles in the fuel rail so I replaced them all when I replaced both fuel pump assemblies
