Dash
Old Feb 26, 2017 | 02:46 PM
cbquinn66's Avatar
cbquinn66
Dash
The hole in the dash just above were the key goes into.What is supposed to be in place of that?
Old Feb 26, 2017 | 02:50 PM
RangerMercMan's Avatar
RangerMercMan
Assuming your truck is a 1966 then it is for the windshield washer push button.
Old Feb 26, 2017 | 02:58 PM
cbquinn66's Avatar
cbquinn66
thanks for the response.
Old Feb 26, 2017 | 05:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Not all 1966's use the push button switch.
2C-11500-A .. Windshield Washer Switch & 1951/52 truck starter button! (Motorcraft SW-287) / Obsolete ~ 10 available NOS
1965 F100/250 / 1966 F100/250 with single speed wipers.
1966 F100/250 with two speed wipers: The washer switch is made as part of the wiper switch.
Old Feb 28, 2017 | 11:08 AM
TA455HO's Avatar
TA455HO
Lead Gopher
For 1966 model year they didn't change to the integrated washer switch for two speed wipers until October, 1965 - serial 760,001 was the cutoff for F100/350. Prior to that they used the separate washer switch with two speed wipers. The separate switch was always used with single speed wipers.
Chad
Old Feb 28, 2017 | 12:16 PM
66v8baby's Avatar
66v8baby
Originally Posted by TA455HO
For 1966 model year they didn't change to the integrated washer switch until October, 1965 - serial 760,001 was the cutoff for F100/350. Prior to that they used the separate washer switch with single and two speed wipers.
Chad
My s/n is 86xxxx (very late production '66) and it had the separate switch and factory wiring that went to it. No matter, I'm planning to install the factory integrated pull to wash switch with a 2 speed motor and install an auxiliary fuel switch in that location.
I'm not sure I can trust the MPC though. Aanything is possible but it's hard to imagine someone going through that much trouble to install a one speed wiper and switch.
Old Feb 28, 2017 | 12:24 PM
NumberDummy
Look up 2C-11500-A and you'll see that in 1966, it was only listed for single speed wipers.
How many '66 F100/250's were assembled between serial number 732,000 & 760,001?
These serial numbers apply to all trucks, Bronco's and Econolines.
Old Feb 28, 2017 | 12:33 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Yes, but we know the MPC has several errors and quite a number of ommissions, too. Ask yourself how trucks prior to 760,001 would trigger the washer pump with the two-speed wiper and I think you can imagine the answer.
I have these trucks in my own list. This is just a small sampling of what was built, so I'd say quite a lot of trucks.
F10AR732072 129 JM F100 V81 G A8 05000 129 4000 89 Early Ranger with red bucket seats Stuffengineer
F10YR732327 115 M F100 C81 G A8 05000 172 4000 72 37 Ford guy
F10YR732707 172 4000 ibmorjamn
F10YD733002 115 M F100 281 C 08 05000 172 4000 62 RIDGWAY66
F11YK734964 129 F F110 K81 A 08 05600 172 4000 75 hotter69
F25YL735260 129 W F251 B81 B4 04900 172 4000 12 66fdtrucknut
F26YR746XXX 120 * F262 D81 A B5K 07700 172 4000 72 0157 82f1006cyl
F10BN746288 115 5M F100 E81 C 08 05000 150 3600 26 300 jage1965
F10BR746604 129 5M F100 D81 C 08 05000 150 3600 74 300 MAP53
F10YK747089 129 * F100 D81 A 08 05000 172 4000 51 0107 SuperSabre
F10AR747677 381 129 4000 reelickj
F26YR747754 120 F260 L81 A B5 06800 172 4000 74 5433 GenX66
F10YK748031 129 HM F100 D81 G C1 05000 172 4000 54 6783 Mercmeister
F10BC748107 129 JH F100 E81 F A8 05000 150 3600 B7 300 6cannons
F26YE749434 120 B F260 381 A B5 06800 172 4000 11 0213 Flareside Ruffasacob
F10AL750805 115 5M F100 E81 C 09 05000 129 4000 31 Enzo500
F10AK752333 129 5M F100 E81 C 09 05000 129 4000 45 hubbytomdaman
F10AL753415 129 H F100 M81 C 09 05000 129 4000 43 1966Jacked4x4
The thing to ask yourself is how many 1966 F100/250 trucks were built in between these serial numbers and up to 760,001.
Thousands?
Old Feb 28, 2017 | 12:40 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Larry, I might be misreading that, but it sounds like yours is a single speed motor and you had the separate push to wash switch - that would be correct for all serial numbers in 1966.
The integrated washer/wiper switch only applied to 2 speed wipers.
Chad
Old Feb 28, 2017 | 01:31 PM
66v8baby's Avatar
66v8baby
Yes, I had a single speed motor with separate switch and a late serial number. From your post it looked like I should have had a 2 speed motor with integrated switch, but maybe I'm missing something.
So perhaps what you meant was if you have a 2 speed motor then beginning with serial number 760001 you got an integrated switch?
Old Feb 28, 2017 | 01:38 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I retyped my post #5 slightly.
In 1966 both single and two speed wipers were available for the entire model year.
Single speed wipers always used the separate washer button.
Two speed wipers used a separate washer button until 760,001 and then went to the integrated washer/wiper switch.
Sometimes my wording might be a bit awkward...but I get there eventually.
Chiefdan
Nov 10, 2018 10:33 AM
lindascott
1961 - 1963 F100 Unibody
Aug 2, 2018 08:58 AM
arvet19
Jul 19, 2017 08:26 AM
tonkaman3
32
Aug 22, 2016 08:38 PM
whackit
Sep 11, 2013 01:34 PM
