Sponsored by: Real Truck
FICM Issues - Please help!
Old Feb 26, 2017 | 12:13 PM
PowerStroker303's Avatar
PowerStroker303
Originally Posted by FICMrepair.com
Not sure whether this was covered in your call with us, but if you have another 6.0 that you could use to test this module in, that would be a fairly straightforward way to rule it in or out.
Hope this helps!
Ed
This was not covered, but unfortunately I do not have a donor 6.0 to try this on.
Ed, would I only be charged shipping and the $75 diagnostic fee if I send in the FICM and it passes tests? I replaced the power supply and see constant volts, so if any failure would be expected it'd be on the logic side. If the logic side is bad how much would I be looking at for a healthy FICM to be delivered?
Old Apr 2, 2023 | 05:45 PM
projectmoneypit's Avatar
projectmoneypit
Did you ever resolve this issue? My truck has the exact same symptoms.
Walleye Hunter
42
Feb 1, 2019 01:43 PM
1985L8000cat3208
Feb 1, 2016 08:38 AM
zimsoundz
Mar 16, 2012 07:18 PM
AndeyHall
Jan 31, 2010 03:07 PM
RLord4268
Apr 8, 2006 09:08 PM
