Personally, it is not about looks of the truck with steels verses aluminums but functionality and longevity of the tires without spending dollars to break down and re-balance tires to rotate the inner rear tires to other positions.
Scraprat, that's a great looking dually. Personally, I can't imagine running steelies in place of the aluminum wheels which look some much better.
For me personally, I've had trouble adding air into the inner wheels. The valve stem extenders seem like they'd make the job a lot easier, but I've heard most end up leaking. I definitely had the problem of the tire shop not re-mounting the wheels so the inner valve stem lines up. It resulted in me having to remove the wheels on one side; no one had put any grease between the aluminum outer and the steel inner...they had practically welded themselves together. Not fun.
I forgot to mention it but you're correct that there is the possibility of the rims sticking like you said which is why I put antiseize on the back of the steel rim that touches the hub and on the inside of the aluminum rim that touches the the steel rim. I have never wrestled with the wheels getting them off since using this method on my '08' dually and now the '16'.
Not knocking your decision, Larry. I just much prefer the looks of the aluminum wheels. I run snow tires in the winter on the factory aluminum / steel rims. The only time the tires get "rotated" is when the winters are put on around Thanksgiving and switched back around Easter. I expect to get 40,000 miles or more from the factory tires. At around a grand for 6 tires, that doesn't seem like too bad a deal.
Not everyone uses "snow tires" nor change them. My truck looks pretty darn good with the steels, Functional Steels on it. I can roate them without any cost to break down and re-balance. What works for you, doesn't always work for others.
I don't mind the look...probably wouldn't do it myself, but doesn't look bad. Just keep em clean so they don't rust...sure you know that already. Nice truck.
