Truck won't start.
Old Feb 25, 2017 | 08:44 PM
Gousetis's Avatar
Gousetis
Truck won't start.
I got the 7.3 Excursion in some deep water today. Front tires were almost all the way under water about an inch less. Tail pipe was half under water. Did not shut off while in water. Now it's a bit colder which I don't think has anything to do with it but just putting it out there. I am unable to start the truck. Will not try to roll over and I am unable to shift gear shifter. Steering wheel is not locked. Not sure but thinking neutral safety switch.
Old Feb 25, 2017 | 08:50 PM
Gousetis's Avatar
Gousetis
Old Feb 25, 2017 | 09:43 PM
Walleye Hunter's Avatar
Walleye Hunter
Well...you probably got your starter wet. I never tried that so I don't know how they like it.
Old Feb 25, 2017 | 10:16 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
You need a new driveway...
Hopefully just your starter. Try to hook a computer to the OBD II port and talk with the computer/check codes. If you got the computer wet, you will know pretty quick.
Old Feb 25, 2017 | 10:24 PM
Gousetis's Avatar
Gousetis
The truck started a few times earlier after the puddle. It is 23 degrees so maybe it does have a big effect. Isn't the computer up high? Instrument panel lights up like it's supposed to
Old Feb 25, 2017 | 11:01 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Computer is mounted right next to the emergency brake in the floorboard. Not much higher than the top of the front wheel.
Old Feb 26, 2017 | 12:13 PM
HKusp's Avatar
HKusp
And the IDM is in the front fender well, and though they are sealed, they don't like water at all.
Old Feb 26, 2017 | 12:16 PM
tommyl's Avatar
tommyl
You say it is not cranking when you turn the key to start! How good are batteries, battery connection, starter?
Old Feb 26, 2017 | 04:29 PM
Gousetis's Avatar
Gousetis
It was the neutral safety switch
Old Feb 26, 2017 | 06:01 PM
stevedrums's Avatar
stevedrums
nice. cheap and easy.
Old Feb 26, 2017 | 06:26 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Just remember your X is not amphibious in the future.
Old Feb 26, 2017 | 07:40 PM
Gousetis's Avatar
Gousetis
wont do it again. Thinking of growing up lol
86sixbanger
May 16, 2012 11:03 PM
glenster
Apr 20, 2012 10:21 AM
4wheelinbroncos
Offroad & 4x4
Mar 29, 2004 04:25 PM
rmroost
Offroad & 4x4
Mar 17, 2004 08:51 PM
retrogod1
Feb 24, 2004 02:35 AM
