Remote keyless entry module
I'm looking for the keyless entry module with part number F3VF-14B128-A. Mine has doe broken or burnt diodes in it. I was going to replace them myself but am being told unless I know the exact specifications for them I won't be able to. I would need the wiring schematic for the boards in the module to get that info. So I'm trying to find a module. I'm being told this will control my speedometer as well. If you have one get with me at shermand34@gmail.com.
Thanks
Dennis Sherman
Thanks
Dennis Sherman
Here is a pic of the module for my 1995 F250 7.3 diesel truck.
You have the 7.3 diesel and they guys in the "1994.5 - 1997 7.3L Power Stroke Diesel" forum here are really good at helping with about any kind of problem, from motor to wiring to fuel. You may just want to start a post there about the shifting problem if the speed sensor in the rear end didn't fix your problem.
Kevin
Kevin
mine looks just like yours. I'll have to figure out how to add a picture. But the numbers I listed is exactly what's on
I don't know if the speedometer has a voltage you can test, but here is a link to a workshop manual.
1996 Bronco/F-Series Workshop Manual
We have only rear ABS brakes on the OBS 7.3 and "Section 06-09A: Brake System, Anti-Lock, Rear" talks about them.
If you go into the brake section it gives some electrical schematics and it shows the VSS. Then it shows it goes to the ABS module behind the glove box (looks like I might have been wrong about it going through the RABS valve).
You could OHM out the sensor at the rear, plug it back in and then find the wires where they go next and OHM them out again and if they are the same then you know your wiring is good to the rear of the truck.
Is the red brake light or the ABS light on in the instrument cluster?
If you need anything else, just ask.
Kevin
you are correct. There's no sticker on mine. I was going off the plastic case as being the number. As for the ABS light. Yes it is on too. I did open up the keyless module and it does have some burned out be broken diodes in it. I appreciate your help a lot.
Dennis
I still don't think the keyless module has anything to do with the speedometer though. It might have a signal that locks the doors when the vehicle is taken out of PARK, but I would think it gets the signal somewhere else and the speedometer doesn't go through it.
My truck is a 1995 and I added the keyless entry module and exterior keypad to it, so from the factory the speedometer worked without the module.
If you have any other questions, just ask.
Kevin
