I did the KOER test on my 90 f-150 today and got these three codes- 25-33-41. I,m new to fuel injection so I need all the help I can get. Hopefully someone can point me in the right direction to fix this.
25=Knock sensor not detected, check the connection. This may be the cause of all the codes.
33=EGR Valve Position Sensor Circuit, EGR Valve Opening Not Detected (Engine Running & Continuous Memory)
Ford MCU System Key On Engine Running (KOER) Self-Test Not Initiated - Could be related to the actual problem, it may go away after the right sensor is replaced (see below).
41=Oxygen Reads Lean - check for a vacuum leak
I would buy a Haynes munual if you haven't already. They are the best for testing individual sensors.
Click HERE for a decent rundown on some of the sensors.
