park brake issues
Old Feb 23, 2017 | 02:31 PM
Billy D. Scott's Avatar
Billy D. Scott
park brake issues
The park brake in my 1994 E350 is useless. I think the issue is cable stretch. I inspected the pedal assembly and I noticed that the "self adjusting" ratchet is at its max, and still there is barely any drum/shoe contact with the pedal to the floor.
If I replace the two rearmost cables/housings, will this solve the cable stretch problem? I'd hate to go through the hassle and parts cost to be left with no improvement. And changing the cable within the pedal assembly looks like a nightmare.
Seems like I could easily remove the steel coupler between the first and intermediate cable and use some cable clamps for adjustment to take up the slack.
Someone has done this, I'm sure?
Old Feb 23, 2017 | 04:09 PM
vettex2's Avatar
vettex2
w/o actually seeing what you have....
get a couple of nuts and cut a slot in them and use them as spacers on the end of the cable to see if that works before you go buying parts
Old Feb 24, 2017 | 04:02 AM
Im50fast's Avatar
Im50fast
I don't believe the cable could have stretched.
I bet your rear brakes need service.
Old Feb 24, 2017 | 11:07 AM
vettex2's Avatar
vettex2
it would be rare but not impossible
numerous things could be wrong
Old Feb 24, 2017 | 11:38 AM
Billy D. Scott
My rear brakes are all new (rotors, shoes, hardware, etc.) It looks peachy back there.
The park brake problem existed prior to the new brakes.
I'm just thinking that the 20 feet of cable could have stretched an inch or so, and the cable housings compressed some, enough to consume the range of auto adjustment in the pedal assembly.
I've read a lot of complaints about bad park brakes in these vans, but I never seem to find a complete answer. I'm at about 8000 lbs, and I NEED a good park brake...
Old Feb 25, 2017 | 12:05 PM
Im50fast's Avatar
Im50fast
i've driven almost 1,000,000 miles in my lifetime and I have never used the parking break to park, nor for an emergency. Never. Stick shift/ automatic - doesn't matter.
I grew up in the Rust Belt where everyone was afraid to use a parking brake because the brake would commonly not release upon using it.
Anyway: no offense- do what you like. I just felt the need to share. Let us know what you find.
Old Mar 1, 2017 | 02:23 PM
Billy D. Scott
You're right. The piece that pushes the forward pads to set the park brake has sheared off the the top of the pads (on both sides). Either the wrong pads were installed or these are just bad pads. Working on a warranty claim, from out of state, not fun.
Old Mar 1, 2017 | 04:57 PM
Im50fast's Avatar
Im50fast
I knew it wasn't the cable
UP_There
Aug 2, 2016 09:04 AM
tjc transport
34
Jul 16, 2016 05:37 AM
hunter301
Nov 12, 2014 07:58 PM
400944
Apr 20, 2008 01:44 PM
StealthWyvern
Mar 20, 2008 09:39 PM
