Alternator Suggestions
Old Feb 26, 2017 | 04:35 PM
Encho's Avatar
Encho
The Southernmost Mod
Originally Posted by rla2005
You increased the amperage capability by ~50%. It's silly to keep the same size charge wire since it was marginal for 95 amps.
Just my opinion
I must say Randy knows his stuff, specially regarding electrical stuff in these trucks. I would definitely follow his advice. And in the end it's worth the small hassle it could mean upgrading the charge cable vs. the possibility to get a fire under the hood.
Old Feb 26, 2017 | 04:36 PM
TexasGuy001's Avatar
TexasGuy001
Just my opinion
The other truck was fine for at least 6 years and this one going on 2 years. I did a 1 wire 100 amp alternator on my 65 Mustang and don't believe the charge wire for it is any larger, but I'll look and see. What your saying makes sense, and it may be something to consider doing. Do you have a suggestion on an OEM wire to use, or should I just make one?
Old Feb 26, 2017 | 09:55 PM
rla2005's Avatar
rla2005
I have read many folks grab the charge wire and fuse from a Taurus.
I purchased mine from RJM before Ryan closed his business. Very thick wire 0/1 gauge perhaps.
The power dropped across a length of wire increases to the square of the current flow. That's why you need to ensure you keep the resistance as low as possible.
hi-jacker
Oct 1, 2018 07:27 PM
panteramatt
Nov 6, 2016 07:33 PM
ac700wildcat
39
Dec 16, 2010 02:48 AM
tdg038
Electrical Systems/Wiring
Mar 26, 2005 11:09 AM
k4uwc
1978 - 1996 Big Bronco
Feb 15, 2004 04:47 PM
