Sponsored by: Halo Lifts
Yet another tire question
Old 02-22-2017, 12:10 PM
CR172's Avatar
CR172
CR172 is offline
I have a 2015 F150 XLT Scab 5.0L that has 32k on the clock. The factory tires are basically gone so it's time to start looking. I'm planning on putting a 2" leveling kit up front, nothing to the rear. I will be running the stock chrome 18" rims. I'm thinking about the General Grabber AT2 in a 275/65R18. This truck is a daily driver on the highway. About the only off roading will be to get to my trailer at the back of the 3.5 acres. I want a quiet tire with a moderate aggressive look. I keep reading conflicting reports on road noise from these tires. Can anyone tell me if these are a noisy tire or not?
Thanks in advance.
Bill
Old 02-22-2017, 01:38 PM
TJReams's Avatar
TJReams
TJReams is offline
I have almost 13,000 om my Hankooks that came on the truck and really like them. They have very good traction on wet roads and have a slightly aggressive tread, quit running, and have worked well in what little mud that I have been in.
Old 02-22-2017, 01:44 PM
CR172's Avatar
CR172
CR172 is offline
When I took mine in for service the last time, I was told I may need new tires before the next service. The stock Hankooks on mine are just about at the wear indicator (all 4) with only 30K miles. True, they do ride nice, but wear way too fast. I'm also looking for a larger tire to fill the wheel wells up more. I just don't want a noisy AT tire for highway use.
Old 02-22-2017, 02:29 PM
JKBrad's Avatar
JKBrad
JKBrad is offline
You can go with a 275/70/18. BF Goodrich makes a Rugged Trail in that size that's P rated. 33" tall and quiet. I also like Bridgestone Dueler A/T Revos for a quiet, smooth ride. I have Toyo Open Country A/T Extremes and they are quite noisy.
285/65/18 is also an option. Those are right at or under 33" depending on who makes them. All tire companies vary a little on size.
I have 295/70/18s on my truck 34.3" tall and they fit well on a stock wheel with a 2.25" leveling kit. It doesn't sound like you want that much tire though.
No experience withe the Grabber A/T IIs, but I see a lot of good reviews.
Old 02-22-2017, 02:44 PM
CR172's Avatar
CR172
CR172 is offline
Have any pictures?
Old 02-22-2017, 02:53 PM
JKBrad's Avatar
JKBrad
JKBrad is offline
Originally Posted by CR172
Have any pictures?
onug's Avatar
onug
onug is offline
I'm assuming your tire is a 275/65 R18 right now. May I ask why you're looking at a leveling kit if you're not going with a larger tire? My truck came with that size tire (275/65 R18) and it doesn't fill up the wheel well enough IMO. I'm looking at tires as well, but maybe going to a 275/70 to add another inch in diameter. Not sure that needs a leveling kit...
Old 02-22-2017, 02:55 PM
onug's Avatar
onug
onug is offline
Brad - Do you have any cupping or wear issues with the 285 on the OEM rim? None of the shops I've visited thus far have recommended that tire (well, haven't suggested it either).
That's one of the tires I'm looking at...bummer it's so noisy
Old 02-22-2017, 02:58 PM
CR172's Avatar
CR172
CR172 is offline
Stock tires are 265/60r18 They are only 30" in diam. I want the leveling kit to get rid of most of the ugly rake they put on these things. Then, with the body raised up, I need a larger tire .....
Old 02-22-2017, 03:01 PM
CR172's Avatar
CR172
CR172 is offline
So, FX4 w/2.25" leveling. Any added to the rear? The FX4 is already taller than a 2WD, so I'm assuming a 2WD with just a 2" lift in front would be about right. I don't want it perfectly level as that makes the front end high when a load is attached.
OH, Nice looking truck.
Old 02-22-2017, 03:28 PM
onug's Avatar
onug
onug is offline
Ahh, okay. So here's my rig with the OEM 275/65 R18 tires. I've got about 500lbs of gear in the back, but still have a 2" rake. If you want to fill up the wheel wells better, I'd go larger than what I have.
Old 02-22-2017, 03:58 PM
JKBrad's Avatar
JKBrad
JKBrad is offline
Thanks. Didn't realize you were 2wd. I think the tire sizes I mentioned above would look just right with a levelling kit.
Mine is stock in the rear. The 295s have no cupping after 9k miles and no rotaions. I'm going to put a taller rear block in soon to get an inch of rear lift.
Old 02-22-2017, 04:05 PM
CR172's Avatar
CR172
CR172 is offline
I agree with your sizes. Some of those are hard to locate in a P metric and/or not be a $300 tire..... The Grabber AT2 come with a 60K mile warranty and a 30 day trial period. I may give them a try and if they are too noisy go with Yoko's or similar.
Old 02-22-2017, 05:02 PM
cdmm151's Avatar
cdmm151
cdmm151 is offline
I had those on my 2005 GMC and they were as good as the K/Os. Did cut fuel mileage. Had to go with a tire that had a little less aggressive tread. I now have the Hankooks on both 2015 Expy and 2016 150 crew. Not to happy with the wear. Like the tire but I am only going to get 35,000 to 40,000. Wish there was a tire like that that would get closer to 55,000 plus.
Old 02-22-2017, 05:09 PM
CR172's Avatar
CR172
CR172 is offline
The factory Hankooks have 30K miles and are down to the wear indicators on all 4 tires. The missus seems to wear out her Yoko's on her Highlander prematurely also....
Did you have the Grabber AT2's? If so, how was the road noise?
Quick Reply: Yet another tire question
