Sponsored by: Halo Lifts
Yet another tire question
Old 02-22-2017, 05:58 PM
JKBrad's Avatar
JKBrad
JKBrad is offline
My Toyos look like they will do 60-70K miles easy. With BFG AT KOs I would get 55k miles.
Old 02-22-2017, 06:14 PM
onug's Avatar
onug
onug is offline
Originally Posted by CR172
Some of those are hard to locate in a P metric and/or not be a $300 tire.....
Yes, that's the problem I'm having too. My size has very limited options that are not heavy, Load E. I'm slowing coming to the conclusion I'll have to go with a heavier tire.
Old 02-22-2017, 06:35 PM
JKBrad's Avatar
JKBrad
JKBrad is offline
Originally Posted by onug
Brad - Do you have any cupping or wear issues with the 285 on the OEM rim? None of the shops I've visited thus far have recommended that tire (well, haven't suggested it either).
That's one of the tires I'm looking at...bummer it's so noisy
I'm guessing it's noisy because it's the Extreme version, which has a deeper tread and larger voids. Most reviews of this tire complement it's relative quiet ride. I would think the non Extreme version would be fine.
No wear issues. They are the smoothest, best balanced large AT tires I've ever had. The Next best were the Bridgstone Dueler Revos. I haven't rotated them either, but will soon as I tend to rotate around 10-15k miles on my vehicles. And I never re-balance my tires. One they're balanced well and don't cause any vibrations, I don't mess with them. I have no tolerance for wheel/tire vibrations.
Old 02-23-2017, 10:25 AM
CR172's Avatar
CR172
CR172 is offline
I think I'm going to go with the Toyo Open Country H/T in the 275/70R18 w/ a 2" level in front only. The tires are 33" tall compared to 30" for the stock tires and basically the same width. Can a place like 4 wheel world re-calibrate the speedo?
Old 02-23-2017, 10:45 AM
JKBrad's Avatar
JKBrad
JKBrad is offline
No place can recalibrate the speedometer, not even the dealer. You will
Need to buy the Hypertech calibrator or an aftermarket tuner.
Old 02-23-2017, 10:48 AM
onug's Avatar
onug
onug is offline
Please post pics when you've got the tires. I'd like to see how it looks.
I recommend checking your speed against a GPS after getting the tires. You might be closer than you think.
Old 02-23-2017, 10:55 AM
CR172's Avatar
CR172
CR172 is offline
Brad, Good to know.
Onug, I'll get both before and after pics. Truck is D.I.R.T.Y at the moment. Garmin is in the console....
I'm going to run over to 4 Wheel World at lunch and see how much damage this causes....
Old 02-23-2017, 11:15 AM
JKBrad's Avatar
JKBrad
JKBrad is offline
With that much of a height difference you will need to recalibrate. Your speedometer will read about 7-8 mph slow.
I used the Speed Box app when calibrating mine. The Ford factory calibration is about 3 mph fast BTW.
Old 02-23-2017, 12:17 PM
onug's Avatar
onug
onug is offline
My truck is about 0.5-1mph slow compared to a GPS app. I should look at it against my Garmin as well. But if I was to jump to the larger tire, I'd only be off by 1-3mph. I'm curious if Ford calibrates each speedo based on tire size or picks a happy medium.
I just did some price shopping as well the 275/70 is actual $40/tire cheaper than my stock 275/65.
Old 02-23-2017, 12:19 PM
CR172's Avatar
CR172
CR172 is offline
Would one notice the difference between a 32.2" and a 33.1" ?
Old 02-23-2017, 02:50 PM
CR172's Avatar
CR172
CR172 is offline
Ouch!..... 4wheel parts doesn't do street tires and want to put me in a Toyo A/T II LT275/70R18. Lift, alignment, tires, etc.... Out the door $1865.00. Is there really 450.00 labor to install a level kit and align?
Old 02-23-2017, 04:02 PM
JKBrad's Avatar
JKBrad
JKBrad is offline
Ask your dealer where they get their trucks leveled or if their own service dept does it. You can get a better price. 4wheel parts will negotiate some too. The Toyo Open Country AT II 275/70/18 was on OEM tire on Super Duty trucks for 2015/16, so your dealer may be able too get a better price for them.
I had my truck done at a local shop with 5 tires (I wanted a matching spare) and an alignment for $1800 even.
  #28
Old 02-23-2017, 04:10 PM
CR172's Avatar
CR172
CR172 is offline
Had no idea a dealer would do a leveling kit.....
I just noticed the quote has an "all inclusive tire warranty - 96.99 and a Xtreme plus warranty 3/36 - 39.99. Mount & balance - 88.00?? seems a bit much to me.
  #29
Old 02-23-2017, 06:35 PM
onug's Avatar
onug
onug is offline
Here are some random thoughts.
1. I'd buy tires from a tire shop with plenty of stores around me. I've had my local 4WP do work on my past rigs, but there's just one store anywhere near me. All the other stores have closed. A few years ago, I had an air leak in an aftermarket wheel (yes, wheel) when I was in a different state. It was great to walk into the local store and say "Fix".
2. I've received multiple quotes from different tire shops around me for both 275/65 and 275/70 tires. Four tires are ranging from $1,050-1,300. I'd also looked at new shocks (Bilstein) that were going to be $850 installed. So your price seems pretty reasonable to me.
3. I've watched a few Youtube videos on installing leveling kits. Our front suspensions are not easy to work around and you'll need an alignment afterwards. All that is a factor in the cost of install.
  #30
Old 02-23-2017, 07:07 PM
Jafo56's Avatar
Jafo56
Jafo56 is offline
I have the general grabber at2 on my 2006 suberduty...they are 35x12.50 ..17s. I like them so far so good ...there quiet.. I have about 3000 miles on them.......I also have a 2016 f-150 and I'm getting ready to do the 2.25 inch leveling kit.... I will be doing 295-70 r18 nitty at tires on the stock 18" chrome wheels......I have seen photos and like that look...it seems like a lot of people are happy with that combo
Quick Reply: Yet another tire question
