My '65 F-100 has a set of the 1980+ aluminum factory 15"x8" wheels on it with the cast metal center caps held on by the three large slotted screws. When I picked up a pair of new tires for the front I wasn't paying attention and when I got home I noticed two of the center cap mounting screws were missing. One of the local Ford dealers actually had them in stock so I thought the problem was solved. It turns out the threaded plastic inserts that the screws thread in to had either broken / disintegrated / are now missing. Does anyone have the part number for those plastic inserts, or know of a suitable replacement?
One of the local Ford dealers actually had them in stock so I thought the problem was solved. It turns out the threaded nylon anchors that the screws thread in to had either broken / disintegrated / are now missing.
Order & Chaos: If you don't mind, please let me know what the going rate for those are, as I found some up here, but they're almost $6.00 ea
Just want to compare the NOS guys numbers to the dealers....
