1978 - 1996 Big Bronco
Crank No Fire
Old Feb 21, 2017 | 02:18 PM
Josh Choroba's Avatar
Josh Choroba
Crank No Fire
95 5.8 351w, replaced the fuel pump, now I'm getting a crank no fire. When I turn the key on you can hear the fuel pump kick on, I checked and I have fuel pressure. I also checked to make sure I'm getting good spark, which I am. Could this be an injector problem?
Old Feb 21, 2017 | 10:20 PM
Encho's Avatar
Encho
The Southernmost Mod
It could be, but why did you replace the fuel pump in the first place? and are you sure you're getting spark at every cylinder? (that usually would lead to a barely-running condition, but have enough cylinders failing and it won't start).
stsscott
41
Apr 11, 2014 02:26 PM
stevenryals
1983 - 2012 Ranger & B-Series
15
Jul 27, 2009 11:06 AM
kpoly3
Modular V8 (4.6L, 5.4L)
Mar 15, 2008 08:38 PM
Makchell
Nov 21, 2004 09:17 PM
78f3504x4
Apr 30, 2003 09:01 PM
