1978 - 1996 Big Bronco
1985 Bronco's engine clicks
Old Feb 19, 2017 | 10:56 PM
Mason Andrews's Avatar
Mason Andrews
I just got this 1985 bronco and we've already replaced the starter and solenoid, but Everytime we try and start it it clicks and the solenoid starts to smoke.
The battery has been fully charged and this engine ran less than 5 months before but it's recently locked up. We can't get it to start but the most recent thing we've thought about doing is spraying some marvel mystery oil down in the spark plug holes and trying to loosen the Pistons.
Any advice here would help I'm hoping to get this truck running!
Old Feb 20, 2017 | 05:59 AM
gatorfor88's Avatar
gatorfor88
Check ALL the cables for dirty connections. If the cable looks questionable replace it.
Old Feb 20, 2017 | 08:59 AM
Mason Andrews
Okay, I'll try that, but should that be a reason we can't even turn the engine with a cheater bar? We pull and pull and push but can't get it to turn up underneath. But I'll check the connections and try again, and come back with whatever the result is!!!
Old Feb 20, 2017 | 01:12 PM
Bruners4's Avatar
Bruners4
You should be able to rotate the crankshaft by using your hands or a wrench. If you pull the starter out, the ring gear teeth will be visible and using them to rotate the engine might help. But I would pull all of the spark plugs out to make sure that it is not hydro locked.
As to the solenoid smoke. At zero RPM, an electrical motor draws maximum amount of current. This is only limited by the energy source and the link with the most resistance. Resistance + current = heat, and this heat causes smoke. So until the cause of the engine not rotating is remedied, I would not use the starting system to attempt to rotate the engine.
joshuatyler1
22
Sep 15, 2017 10:36 PM
Vanceone
13
Feb 14, 2016 12:03 PM
deltasoft
63
Jul 14, 2008 09:09 PM
Chevythunder7578
Apr 16, 2004 10:09 PM
heybrent
May 23, 2002 05:18 PM
