Sponsored by: Kumho
Pro Comp 22410's
Old Feb 19, 2017 | 10:24 PM
mason97x's Avatar
mason97x
Pro Comp 22410's
Hello all, my name is Mason and I'm a new member to the forum although I've been to the site many times before. I have a 2000 F350 7.3 ccsb srw, with 215,000 miles on it. I am planning on installing pro comp 22410 springs on the front with an adjustable trac bar and bilstein shocks. The rear springs are completely shot with a couple leafs broken off. The truck is used to tow occasionally and I need new springs for it. I had planned on removing the rear 3.75" blocks and installing the pro comp 22415 springs in the rear rather than using oem springs but was told this would not work. I plan to put 35's on it and wanted enough clearance in the front, which the 22410's will provide but Im not sure exactly what I should do to achieve a level stance, or even a slight rake. Any thoughts would be greatly appreciated!
Old Mar 2, 2017 | 08:02 PM
Blakshukvw's Avatar
Blakshukvw
The 410 shows to be a 4" and the 415 shows to be a 5". So if that's true you should have some rake.
Old Mar 3, 2017 | 10:15 AM
mason97x's Avatar
mason97x
Okay thanks!
Jrn2786
Jun 17, 2016 06:19 AM
myblkex
Aug 14, 2009 10:08 AM
Pappys53
Jun 28, 2009 05:35 PM
makeoutmusic
Nov 8, 2007 10:52 AM
