I'm in need of a diagram for the front wheel spindle on a 1995 f350 7.5L with 4x4 suspension. The hubs are the manually locking type. I need to replace the bushing
You mean the wheel bearings?
In your pic of the spindle there are the inner "races" of both wheel bearings. is that what you are looking for?
I was looking for a picture diagram. I have since decided to replace bearings on both sides rather than just the one(pictured) to figure out what pieces were destroyed. Also the threading on the driver side spindle is ground down
Found a spindle. 4wheel parts was able to order one. Locking hubs were replaced as well. Got a rotor/hub assembly from a junkyard (ford can no longer order them)
