Motorcraft 10W-30: Good/bad/stupid?
Old 02-18-2017, 08:44 PM
Icthus in AK's Avatar
Icthus in AK
Icthus in AK is offline
Just picked up 15qts of Motorcraft diesel 10W-30 oil because I couldn't find any of the oils listed on various CJ-4 compliant or new Ford compliant lists for the 6.7L Powerstroke. So... It's not synthetic but it's Ford's brand so i should be fine, right? I can't find any of the listed oils in Anchorage; should i stick with this? Go with Amsoil? What? Thanks for your thoughts..
Old 02-18-2017, 08:49 PM
Icthus in AK
For what it's worth I've used Rotella T-6 full synthetic 5W-40 exclusively. Truck has 39k miles.
Old 02-18-2017, 09:00 PM
tracyclifton's Avatar
tracyclifton
tracyclifton is offline
Rotella here also. I think most people are using it. If you can get it that's what I would do. And when you do that first change install some type of drain valve. You will be glad you did.
Old 02-18-2017, 09:27 PM
Icthus in AK
Sorry; clarification:. I've had the truck 3 years and have used Rotella T-6 up until Ford changed their requirements and stated CK-4 oils are now no bueno. I'm trying to figure out what to switch to...
Old 02-18-2017, 09:48 PM
tracyclifton
So are you saying that Ford says Rotella can not be used in the 6.7 anymore????
Old 02-18-2017, 09:57 PM
EO2SeaBee's Avatar
EO2SeaBee
EO2SeaBee is offline
I was lucky enough a few weeks ago to find the old style CJ-4 at Tractor supply, but I suspect that future changes for me will be with Valvoline Premium Blue - at least until Ford and Shell come to some sort of agreement.
Old 02-18-2017, 10:02 PM
FishOnOne's Avatar
FishOnOne
FishOnOne is offline
Received 1,447 Likes on 893 Posts
Shells 5W40 API CK4 oil has not been approved by Ford and has not met Ford latest oil specification.
Old 02-18-2017, 10:16 PM
Superdave71's Avatar
Superdave71
Superdave71 is offline
I've chosen to use the motocraft 10/30 as well until this settles out. On shells website they have expressed their commitment to meet Fords spec. I'll use mc until that occurs.
Old 02-18-2017, 10:27 PM
skanj0's Avatar
skanj0
skanj0 is offline
Valvoline 5w40 Premium Blue Extreme is approved in CJ-4 and is on the approved CK-4 list. I get it at my local Napa Auto.
Old 02-19-2017, 12:24 AM
Lubbockguy1979's Avatar
Lubbockguy1979
Lubbockguy1979 is offline
Ive been using it in my old 6.0 and current 6.0. Almost to the first oil change on the 6.7 and im leaning twards it on it as well. I figure it whats already in the truck why not.
Old 02-19-2017, 05:08 AM
tracyclifton
OK I'm glad I stumbled upon this before my next oil change. I guess I will he shopping for a new oil. Thanks for the video and all the info.
Old 02-19-2017, 07:12 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
I can mix my existing last gallon of T6 with the valvoline premium blue 5/40 right?
Old 02-19-2017, 11:56 AM
bobv60's Avatar
bobv60
bobv60 is offline
I did similar, only I went with the 15w-40 MC. I would bet that Shell does eventually meet the ford requirements, but until then MC is what I will be running
Old 02-19-2017, 12:03 PM
SkiSmuggs's Avatar
SkiSmuggs
SkiSmuggs is offline
Here is the approved list from Ford.
File Type: pdf
Old 02-19-2017, 12:25 PM
FishOnOne's Avatar
FishOnOne
I noticed that for Shell the only approved oil on Ford's list is the 10W30. I have a gallon container of this oil and noticed it has the API SM rating instead of the SN rating which reduces Zinc and Phos. to even lower numbers.
Quick Reply: Motorcraft 10W-30: Good/bad/stupid?
