Dana 60 information please
Old Feb 17, 2017 | 01:31 PM
SVTDriver97's Avatar
SVTDriver97
Hello fellow members, I have a lead on a Dana 60 kingpin solid axle and wanted to know what to look for when buying one? If the kingpins are toast I know it can be fixed, but I'm wondering what tags or markings should I look for to make sure it is what it is? Ditto with the rear end.
It would be coming out of a 87 F350, so I'm pretty sure it is a Dana, but just want to make sure.
Thanks
Old Feb 17, 2017 | 01:39 PM
Franklin2's Avatar
Franklin2
The rearend is more than likely a Ford Sterling. If the rear cover on the rearend has no oil fill plug, then it is the Ford 10.25 Sterling rearend. If the rear cover does have a fill plug, then it is a dana.
Here is some info for the front dana 60. BillaVista.com-Dana 60 Front Axles by BOM Number Tech Article by BillaVista
Old Feb 17, 2017 | 03:53 PM
SVTDriver97
You sir, are the man!
That's EXACTLY what I was looking for. It tells me I can't give you anymore reps unfortunately
Thanks again!
SVTDriver97
Feb 17, 2017 06:48 AM
DJOHNSTON78
Aug 10, 2008 03:15 PM
offroad464
Offroad & 4x4
Sep 27, 2004 07:30 AM
