How accurate is DPF percentage?
I drive 100 miles on a slow day, more on a busy day so 200 miles can be rather quick. I also drive a lot of little 2 lane roads and have had the joy of experiencing those wrecks in front of me where I got to sit and enjoy the scenery for 2 - 3 hours while we waited on things to clear. Being on a countdown in that situation would make me crazy.
But I do plan on getting lower than 200 miles to empty on the DEF this time. I really thought 350 to empty would have been enough. I think I'll shoot for 100 just for grins. And I'm only going to add 1 jug at that point unless I need to attempt to add the whole 5 gallons.
I hate to have to clear the warning message when I start the truck. So I never let it get into the countdown, And I don't have any problems.
DEF crystalizes very easily. (Look at the side of your truck after you spill some) I suspect some of the problems is the crystals coating sensor that are above the fluid line or even clogging the filler hose. It's got to be difficult to get accurate readings with a product that crystallizes when ever it hits air.
For me I top off the DEF at the pump when I'm getting fuel if I notice it's under half a tank. Sometimes that is 2 gallons, Sometimes that is 4 gallons. I don't overthink it, It's takes 2-3 minute while I'm already stopped filling the fuel tank to grab the DEF hose and top off the DEF tank.
Interesting they increased the size of the tank. You have a gauge that kinda shows percentage of full, like a fuel gauge, right? Does it seem to be accurate?
Also, you have to remember, Ford does NOT manufacture their DEF. They contract with a company to make the DEF for them and packaged with their Motorcraft label on the jug.
All DEF will be 32.5% urea. There will be slight variations in DEF including Ford/Motorcraft DEF.
#28
If it can be off so much in one direction, I'd be scared it could be off the other direction too and suddenly run out of DEF and depower the engine with 100 miles to go. Maybe it only underestimates the amount of fluid in the tank.
#29
#30
