T56 Swap?!?
Old Feb 15, 2017 | 11:26 PM
c0mpt3d's Avatar
c0mpt3d
T56 Swap?!?
Has anyone looked into the possibility of this swap? Planning to build a long bed sport truck.
Old Feb 15, 2017 | 11:43 PM
c0mpt3d's Avatar
c0mpt3d
Also considering Crown Vic suspension for the handling.
Old Feb 16, 2017 | 06:49 AM
Motorhead351's Avatar
Motorhead351
Search nloc(dot)net, there used to be a good write up for a TKO I believe.
Also at nloc(dot)net, a thread showing the crown vic install, on a bronco frame, same would apply to your truck. Its not a bolt in deal, as it is with the 67-79 trucks.
Just food for thought, factory M5R2 will handle a healthy v8 just fine and lowering the stock suspension, will allow it to handle a lil better, both much more budget friendly.
Old Feb 16, 2017 | 07:15 AM
'89F2urd's Avatar
'89F2urd
assuming its 2wd, its a very straight forward swap.
it'll cost a pretty penny as well, unless you are lucky enough to source a t56/sbf bell used...which wont be easy.
Old Feb 16, 2017 | 05:30 PM
Diesel_Brad's Avatar
Diesel_Brad
how is a t56 different than another trans for how it bolts to the bell?
Old Feb 16, 2017 | 06:24 PM
Lead Head's Avatar
Lead Head
The T56 was never offered behind a SBF engine, so factory bell housings do not exist.
Old Feb 16, 2017 | 07:56 PM
Diesel_Brad
Last I checked it is a universal 4 bolt pattern for bell housings
or is the t56 different?
Old Feb 16, 2017 | 09:05 PM
raystankewitz's Avatar
raystankewitz
The T56 needs a bell with a huge hole in it. The nose end of the tranny is bigger than the main body is. No factory installed SBF had this trans behind it. An aftermarket bell is available from several sources, though.
Old Feb 16, 2017 | 11:13 PM
Lead Head's Avatar
Lead Head
While many of the Tremec 5-speeds use the "GM/Muncie" 4-bolt transmission-bellhousing pattern, the T56 is different.
Old Feb 17, 2017 | 06:20 AM
Diesel_Brad
Ok, thanks guys
Old Feb 17, 2017 | 09:07 AM
'89F2urd's Avatar
'89F2urd
What they said. It's not an issue except for cost.
AliceSML79
Apr 24, 2017 11:34 AM
Ziegelsteinfaust
Feb 18, 2011 11:29 PM
-rc-
Sep 9, 2004 11:27 PM
Jake65
Jan 26, 2003 04:11 PM
