EGR system operation?
Old Feb 15, 2017 | 02:34 PM
Justus6.0L's Avatar
Justus6.0L
Question EGR system operation?
Does anyone know of a link to a good explanation of how the EGR and intake system work on 6.0Ls? I am trying to understand how the EGR and intake work together and understand the general operation of the system.
Thanks.
Old Feb 15, 2017 | 02:48 PM
2006powerstroke90's Avatar
2006powerstroke90
https://www.dieselnet.com/tech/engine_egr_control.php
Old Feb 15, 2017 | 03:00 PM
Justus6.0L's Avatar
Justus6.0L
Originally Posted by 2006powerstroke90
Thank you very much for the information, but I am looking for 6.0L specific, and mostly how it interfaces with the intake manifold, and general operation and how the intake works also.
Old Feb 15, 2017 | 03:14 PM
tfunk88's Avatar
tfunk88
Not sure how much you want, but the way the intake works is there's air in it (usually pressurized by the turbo) and when the piston is falling and intake valves open it draws air into the cylinder. There is a pipe coming off the exhaust up-pipe that draws air off the exhaust and feeds it through an EGR cooler into a passage in the intake, which is blocked by the egr valve. Sometimes the egr valve opens and allows this exhaust gas to pass into the intake so that ignition temps don't get too high and cause high levels of nitrogen oxides to form
Old Feb 15, 2017 | 03:37 PM
Justus6.0L's Avatar
Justus6.0L
That is exactly what I wanted. I thought that the intake had exhaust running through it also. Now I understand, thanks.
chi6488
6.4L Power Stroke Diesel
Feb 5, 2012 04:43 PM
pstrang
Feb 12, 2007 01:29 PM
monkei
1978 - 1996 Big Bronco
13
Oct 8, 2003 06:45 PM
VIBR8R
Mar 23, 2003 07:49 PM
redstone
Mar 22, 2001 02:42 AM
