Looks like now the radiator in starting to seep a little between the core and the plastic sides. Couple questions.
Whats the best replacement that wont cost a ton.
Would this have anything to do with the intermittent not starting when warm.
Looks like a nice radiator there. I went with the radiator bpd sells. The radiator has been great. Only problem I've had is with the drain valve at the bottom. Had to replace it a few times because the oring doesn't seal after its been opened. Bpd sent me free a replacement though.
I seem to be remembering that some of the aftermarket radiators don't have all the cooling rows as a stock radiator. Just make sure whatever you get has the cooling capacity you need.
