F350 vs F450, what are the differences?
I am debating between a '17 F350 and a '17 F450, I have only been able to test drive a few F350s as not to many local dealerships have 450's on the lot. I have done a ton of research, but have questions as to a few of the differences I was told by salesmen (you know, they guys that don't know crap about what they sell).
True or false:
The 450 doesn't support the TPMS because the 110PSI tires.
The 450 rides exactly the same as the 350.
The 450 has a better turning radius than the 350.
It takes longer to get a 450 than a 350 when you order.
I hate to place an order for an $80+K truck that I haven't been able to at least test drive something similar. All the salesmen keep telling me the ride is no different than the 350's on their lot that I have test drove (all with 4.10's so it should be close to comparable). I find that a little hard to believe as I know that the tires themselves are stiffer and should produce at least a slightly stiffer ride, but hopefully not as stiff as the 07 Ram I would be trading in on it.
True or false:
True or false questions:
1. I'm not sure. I don't think they do but I may be wrong.
2. False. The larger heavier wheels and tires and stiffer springs make the 450 ride worse. If you daily drive, it might be a factor.
3. True. 450 has widetrack front axle allowing tighter turning.
4. I believe true. From what I have heard it takes longer to get a 450. I have yet to see a 450 on lots. Seen plenty of 350's.
What are you towing and how often do you tow it? I personally want a 350 drw because it offers VERY close towing to the 450 and a better ride. Also rear axle is the same on the 350 vs 450 so no difference there and I believe front axle is same rating as well just the 450 can turn sharper like I said. If you tow a lot, like 25k+, often (like on a regular basis) then I would go for the 450. I want the 350 because most of the time I will be towing around 20k but like and will use capability of the occasional (admitted very occasional but it still will happen) 30k when needed and want a nicer riding truck because it will be my daily. The towing capacity used to be much bigger between the 350 and 450 but now I believe it's only about 1200lbs(31,300 vs 32,500). Also payload is higher by about 1000lbs I think in the 350. I know in reality the 450 would be higher but on paper and legally the 350 is.
I feel a little dumb answering what I tow because it is so much lighter than some other guys, but I will explain more after I answer the question.
My 5th wheel camper is only ~15K, my gooseneck car hauler is just under 10K with my drag car, but can handle 14K if I put a heavier car/truck on it, I also have a gooseneck debris/dump trailer that is full of gravel for the new hardscape work we are doing around the house and I haven't weighed it but it stressed my current truck more than either of the other 2 mentioned above when I brought it home with 6 yards of gravel (rough guess 17-18K, but maybe more).
I know my weights do not "Require" a F450, heck maybe even not a dually to some people as my current truck is a SRW. However, those people aren't married to my wife, nor do they do long distance RV trips with a 7yr old and a 3.5yr old...
Here is what my wife want's in our next truck:
"The biggest truck so when/if we upgrade our 5th wheel, we don't have to worry about the truck being able to handle it, it must be a dually" and in other conversations she says "I want to to be quiet and comfortable for the long cross country trips we take".
Also, the truck is rarely used as a daily driver, maybe a couple times a month without a trailer of some sort on it.
So with the capabilities so close, but the nicer ride in the 350, and since I will not be stretching the limits of those capabilities do you guys think I'd be happier with the 350 over the 450?
Thanks for the quick answers.
My family and I spent quite a while test driving both. They rode nearly identical. If I wasn't making the crazy tight turns the F450 can make, I don't think any of us could tell the difference from the inside.
The F450 is WAY easier to park and navigate in tight spaces (e.g. parking lots, city streets). I'm sure it will be easier to put my camper on the spots I want with the wide-track turning as well.
I take it that benefits of the 7.5' smaller turning circle aren't enough to offset the ride difference for you? The bigger brakes are nice as well - the brake pads are WAY bigger on the F450.
brett
Man I love my 450. However, unless you really need the benefit of the tigger turning and bigger brakes the 350 would be the best choice. People love their 350s and live with the turning radius of it. If I ordered again, I'd get a 450 but we use it. If you travel where the roads suck or used up asphalt it's gonna be a white knuckled ride. It'll send you all over. That's the only negative. I have yet to have my truck downshift when pulling. While waiting on the new tractor the most I've pulled has only been about 12k but it's a hoss
brett
brett
From my test drives, both the F350 DRW and F450 bounced around some when the road was rough. Maybe I didn't have enough seat time to discern the difference, but I think a F350 DRW with 80 PSI in the rear tires bounces similarly to a F450 running 70 PSI (which is more than enough for the 9900# rating according to the tire manufacturer).
