timing
Old Aug 29, 2003 | 12:18 AM
speedy252f's Avatar
speedy252f
timing
i have a 1984 Ford E-150 I6. How can i get the timing perfect?
its stock
Old Aug 29, 2003 | 07:37 AM
Katmandu2's Avatar
Katmandu2
timing
Use a timing light.
Why not bump the timing up a few degrees and get a better running 300 ??
Old Aug 29, 2003 | 08:53 PM
rhetor's Avatar
rhetor
timing
if you don't have a light you can do it by ear...
Stock timing is 10* BTDC, my 300 seems to run best with no valve clatter at 12-13* BTDC max.
make sure you unplug the SPOUT connector before you change the timing so that you get the accurate base timing.
