problem?
Old Aug 28, 2003 | 03:43 PM
ndntruck's Avatar
ndntruck
problem?
my 89 F-150 ha a little prolbem i hope. It sometimes does not want to start it will crank all day but not run, sometimes it does
run then it justs quits. I have had my ing control module, ing coil tested, new spk plugs and new fuel filter put on. I have been told that my fuel pressure may be the culpret but when I changed my fuel filter I had a gasoline shower, I did that to see if I do have pressure which I do CAN ANYONE HELP!!!!!!!
Old Aug 28, 2003 | 04:44 PM
Tectron1's Avatar
Tectron1
problem?
Check the ECC relay to see if its working, I just went through this a couple months ago with an 89 f150 5.0. The relay is located on the drivers side fender well next to the fuel pump relay.
Hope this helps.
Old Aug 28, 2003 | 04:53 PM
ndntruck's Avatar
ndntruck
problem?
ecc relay what is that unabbrevaited?????
Old Aug 28, 2003 | 05:31 PM
Silver Streak's Avatar
Silver Streak
problem?
It's actually EEC and it stands for Electronic Engine Control. This is basically the computer system that controls the powertrain. If it loses power the truck shuts off.
Old Aug 28, 2003 | 05:40 PM
ndntruck's Avatar
ndntruck
problem?
ok now if this is the prolbem what then!??!?!?!?:-staun
Silver Streak
problem?
Replace the relay.
Old Aug 28, 2003 | 09:01 PM
Tectron1's Avatar
Tectron1
problem?
My Bad, I knew it was for some kind of engine control.
Old Aug 29, 2003 | 02:01 PM
inlineguy's Avatar
inlineguy
problem?
my truck has that problem but the wire goin into the relay is all corroded and isn't connected to the plug anymore any ideas
Old Aug 29, 2003 | 09:41 PM
Tectron1's Avatar
Tectron1
problem?
Are you sure there is no contact at all? does it do it when it gets damp out. I wouldnt think it would run since if that relay doesnt work nothing else will work, since its at the begining of the circut.
Id go to a salvage yard and clip off a plug from another truck and replace your broken one and buy a new relay, corrosion was the culprit with mine to.
Old Aug 29, 2003 | 10:13 PM
inlineguy's Avatar
inlineguy
problem?
it had partial contact and was running like **** run fine for a biit then runn die run die. then just didn't run thats when i started to look hard and foud the problem
Old Aug 29, 2003 | 10:52 PM
skidj0003's Avatar
skidj0003
problem?
I recently replaced the EEC power relay. I bought two replacements, from my local Ford dealer and Advance, that did not work. The parts people gave me the relay indicated by their parts computer. When installed the truck would not start, Fortunately the original relay still worked and would alow the engine to start when reinstalled. On my third trip an experienced man at Advance suggested a Sorensen MR12 universal relay. It worked and is still working.
Old Aug 29, 2003 | 10:54 PM
skidj0003's Avatar
skidj0003
problem?
There is also a fuel pump relay located near the EEC relay. It can also shut down the engine.
Old Aug 29, 2003 | 10:58 PM
inlineguy's Avatar
inlineguy
Talking problem?
thanks for the info ill replace both there like 22 bucks canadian from the local ford dealer ill get new connecters at the scrap yard down the street just gotta 11 year olf fleet of f-150's
