Sponsored by: Real Truck
Bleeding break problem
Old Feb 12, 2017 | 05:15 PM
Michaelmx's Avatar
Michaelmx
4wd Low
Hi all,
2001 Ford f350. I had to replace all 4 calipers and the master cylinder.
I did not bench bleed the master.
After bleeding all four calipers, the pedal still goes to the floor, and even if I pump them I cant build up any pressure.
I have bled brakes before and know to start at rr then lr, rf and lf.
Should I remove the master and bench bleed?
Any suggestion would be great as I am stumped.
Old Feb 12, 2017 | 05:53 PM
erikkloss's Avatar
erikkloss
Did you try bleeding them using a tube into a container like it was posted on your other thread? If you did and it did not work, then take off 1 of the brake lines going into your master and push the pedal (holding a rag over hole so fluid does not spray all over) and see if the master is pushing fluid.
Old Feb 12, 2017 | 06:06 PM
jschira's Avatar
jschira
Yes. I have had this problem before and have solved it by always bench bleeding the master.
Also, and sorry if you find this insulting, but people have made this mistake before, the caliper bleed screws need to be on the top. If they are on the bottom, you have then on the wrong side.
Old Feb 12, 2017 | 06:13 PM
82_F100_300Six's Avatar
82_F100_300Six
I bleed the master cylinder after its installed with a little NAPA kit I bought in 92. It has different sized plugs that a length of tubing fits on and a clip holds each tube going into the front and rear chambers
Old Feb 12, 2017 | 06:22 PM
Michaelmx's Avatar
Michaelmx
4wd Low
Holy smokes! Dont worry about insulting me! I have the rear calipers on backwards! Seriously thank you.
Old Feb 12, 2017 | 07:40 PM
Michaelmx's Avatar
Michaelmx
4wd Low
BTW, off hand do I need to swap out the brackets as well, they look the same to me?
Old Feb 12, 2017 | 08:48 PM
jschira's Avatar
jschira
Sorry, I do not know the answer to that question.
Old Feb 12, 2017 | 09:00 PM
Michaelmx's Avatar
Michaelmx
4wd Low
OK no problem I swapped them out just in case, now I just need someone to help me bleed again, but I am sure that was the issue, thanks to all again!
Old Feb 12, 2017 | 11:34 PM
99f350sd's Avatar
99f350sd
I just crack the bleeder and let it drip .....works everytime.
ihcc104
30
Dec 18, 2014 09:47 PM
85AustinTucker
Mar 7, 2014 11:06 AM
Troublecreek
Jan 31, 2010 06:27 PM
pipman76
Mar 28, 2008 04:21 PM
koshare
Nov 18, 2002 07:59 AM
