bleeding brakes????
Old Mar 28, 2008 | 03:24 PM
pipman76's Avatar
pipman76
Thumbs up bleeding brakes????
i dont know if anyone remembers a few weeks back when i posted on here that i purchased another f-100 74 and found that the fluid was deluted with motor oil,so the only soultion was to replace everything,i so happened to have a parts truck that i used to replace all the metal lines and then i replace the master cylinder,calipers,wheel cylinders 7 RUBBER LINES,ive never did alot of brake work so my question is what are the steps needed to get my brake petal back up do i need to open all bleeders at one time since the whole system has been opened up.i plan on having my wife pump the pedal for me
any help please
Old Mar 28, 2008 | 03:52 PM
scrapyardking's Avatar
scrapyardking
Blead them one at a time, starting from the farthest away from the master cylender to the closest
Old Mar 28, 2008 | 04:12 PM
pipman76's Avatar
pipman76
do i need to bleed the master cylinder first???
Old Mar 28, 2008 | 04:21 PM
seafire's Avatar
seafire
Bleed your master cylinder first, then you can start on the back brakes. Before you insteal the master cylinder. Bench bleed the master first. All you need to do is take a short hose attach it to the one of the output lines, put back into the cylinder and fill the master cylinder. Take a blunt object and puch on the back of the cylinder sleve. This pre-bleeds the master.
