8BA fuel line connection
Old Feb 12, 2017 | 04:28 PM
F-1's Avatar
F-1
Can someone tell me what I'm doing wrong with this carb flex line and cooper fuel line connection?
The fitting that came w/ the cooper fuel line screws into the flex female end without the furrel(sp?) just fine but won't fit in with them (fitting & furrel) together?
Old Feb 12, 2017 | 05:13 PM
artscott61's Avatar
artscott61
Veteran: Navy
Looks to me like the nut itself will clamp down. The Ferrel is for a compression fitting I could be wrong but then stranger things have happened. Someone else will let us know I am sure. I would have to get my book out but now I am thinking that that might a flare end.
Old Feb 12, 2017 | 05:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Copper isn't recommended for fuel lines, it gets brittle from vibration and cracks. Use steel brake line, it comes with the correct flare fittings already.
Old Feb 12, 2017 | 06:09 PM
F-1's Avatar
F-1
steel brake lines appear smaller in diameter than cooper fuel line..is that an issue?
Old Feb 12, 2017 | 07:05 PM
raytasch's Avatar
raytasch
Believe Nothing
Steel line comes in the correct size. Check a good parts store. Probably even have it in the correct or usable length.
Old Feb 12, 2017 | 09:04 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It may be called Fuel Line in the proper 5/16" diameter, but it's steel
Old Feb 13, 2017 | 10:31 AM
F-1's Avatar
F-1
Thanks..I'll start searching
farmnaggie
Oct 18, 2014 11:52 PM
farmnaggie
Sep 23, 2014 08:36 PM
SideWinder4.9l
Feb 9, 2012 06:34 AM
Suomi Powerstroke
Nov 16, 2009 10:10 AM
tbm3fan
Nov 18, 2008 09:06 PM
