Low tire pressure indicator
Old Feb 10, 2017 | 06:49 PM
jimzpsd's Avatar
jimzpsd
Is there a way to "trick" this sensor that all of my tires are at the proper psi? If I put in the recommended amount of air, the truck bounces or dribbles like a basketball on road bumps and rides too hard. I had a 1997 F-350 for twenty years and put 330k miles on it when I sold it to get this new truck, and I always would keep 50 psi in all the tires, rode nice too and tires would last around 75/80k miles, then I would air them up if needed, but as a daily driver it was sweet.
I have 50 psi in mine now and love it, but the darn light is annoying me. Any ideas?
Old Feb 10, 2017 | 07:04 PM
camping nut's Avatar
camping nut
I think it can be re-programed in the computer, if not an old trick was to put four sensors in the spare tire and keep the spare at 80 psi not sure if that would work on a 2017 either.
Old Feb 10, 2017 | 10:41 PM
MagneticTiger's Avatar
MagneticTiger
Yep! You can reprogram that with forscan.
Old Feb 11, 2017 | 04:26 PM
jimzpsd's Avatar
jimzpsd
Is the forscan tool a dealer tool? I went to the dealer and they told me they can no longer change this setting because of the DOT.
Old Feb 11, 2017 | 04:32 PM
MagneticTiger
IDS is the dealer tool. It can do more than forscan, but forscan is a great tool for consumers to have.
This thread shows you everything you need to know!
https://www.ford-trucks.com/forums/1...readsheet.html
Basically, you buy an OBDII Scan tool that can connect to a computer, like this one:
Amazon Amazon
Then, using forscan software, you can connect to the truck and modify the comptuer settings.
Good luck!
Old Feb 11, 2017 | 05:18 PM
jimzpsd's Avatar
jimzpsd
Nice, thank you
Old Feb 9, 2021 | 09:48 AM
TB250's Avatar
TB250
Won't work. It's the rotation of the tire that wakes the TPMS sensor up from sleep so they would never turn on located in the spare.
richhrub
Feb 19, 2014 06:37 AM
itry2fly
Jan 10, 2013 07:29 PM
bill buxton
Nov 18, 2010 01:54 PM
LACityFD
2004 - 2008 F150
Feb 25, 2008 08:14 AM
rmartin11
Jul 16, 2004 09:34 AM
