Sponsored by: Real Truck
Shock Recommendations?
Old Feb 22, 2017 | 08:57 AM
  #46
Rancho Suspension's Avatar
Rancho Suspension
Former Vendor
As long as Monroe is in business (100+ years at this!) and you have that receipt you are covered by the warranty. Monroe is our parent company
Originally Posted by super 6.8
Unfortunately I do. Bad experience. I will never buy them again.
To be honest, the Monroe Reflex I replaced them with have a noticeably better ride to them. As long as Oreilly's is in business they will truly be a lifetime shock too.
Old Feb 24, 2017 | 10:16 AM
  #47
BigBlue13's Avatar
BigBlue13
Old Feb 24, 2017 | 10:30 AM
  #48
Rancho Suspension
Former Vendor
It might... sorry so vague.
In the past there was a "shock" section and a shock/system section on the rebates. It as based on a $ amount spent, so people would buy the stabilizers and it would "bump' up the rebate for them. I should know more next week and we will all know March 1st, for sure.
Originally Posted by BigBlue13
Does the rebate work for the dual steering stabilizer kit?
Old Feb 24, 2017 | 10:47 AM
  #49
530ktmpilot's Avatar
530ktmpilot
I have thr rancho 9000's and they work great! If you want a smooth ride unloaded they can be tuned to ride like a car. When loaded up with bikes in the bed and the trailer on the hitch, I run them near max setting and ride is very controlled.
I havent experienced the rusting problem so far but will keep an eye on them. If there is an issue, I'd probably choose to repaint them as I'm not ready to give up the functionality for some chipped paint and rusting metal. Mine seemed to have a good drain around the bottom of the boot so maybe the later model ones use an improved boot design?
Old Feb 24, 2017 | 10:55 AM
  #50
Rancho Suspension
Former Vendor
Talking
Same boot design, often times it isn't installed optimally.
Any painted shock can get damaged.
I have seen $1000 dollar shocks pit and damaged.
The road is nasty.
I havent experienced the rusting problem so far but will keep an eye on them. If there is an issue, I'd probably chose to repaint them as I'm not ready to give up the functionality for some chipped paint and rusting metal. Mine seemed to have a good drain around the bottom of the boot so maybe the later model ones use an improved boot design?
Old Feb 24, 2017 | 04:08 PM
  #51
russ68's Avatar
russ68
8th Gear
I just put on Bilstein's all the way around. 2014 F350 had 100K on them (original shocks). Can't really say it rides any different - still feels like a F350.
Old Feb 27, 2017 | 10:21 AM
  #52
ed foster's Avatar
ed foster
A lot of interesting talk about Ranchos and Bilsteins. Does anyone have any experience with KYB Monomax?
Old Mar 1, 2017 | 11:24 AM
  #53
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
What does "installed optimally" look like?
Does the "optimal" installation method look any different than the photo on the side of the box the Rancho shock ships in?
Does the optimal installation method differ from the photo in the banner ad of your signature?
Old Mar 1, 2017 | 11:30 AM
  #54
Rancho Suspension
Former Vendor
You want it so that the "weep" cut allows debris and weather to get out at the base of the shock.
The image in my signature is a glamour shot. I don't see a zip tie on it.
I also don't run a zip tie on mine...
Old Mar 1, 2017 | 01:34 PM
  #55
JeepPuller's Avatar
JeepPuller
I can see the advantage of no zip tie; this allows everything to 'drain'.
I suspect that not having a zip tie on will the shaft to be exposed, but this is likely to happen at low speed so less chance of dings to the shaft.
Has this been your experience?
Old Mar 1, 2017 | 02:34 PM
  #56
Rancho Suspension
Former Vendor
Most of the time the boot should be long enough to protect the shock rod.
Old Mar 1, 2017 | 02:42 PM
  #57
BigBlue13's Avatar
BigBlue13
Old Mar 1, 2017 | 02:47 PM
  #58
Rancho Suspension
Former Vendor
It is part of the rebate but falls under the "Qualifying lift kit and Rancho parts purchase", so if you bought a system AND that it would qualify. Often times if it enough to take a customer to the next rebate level.
Ok rancho, is the RS98509 steering stabilizer kit part of the rebate? I'm having a hard time deciphering the rebate terms
Old Mar 1, 2017 | 02:53 PM
  #59
BigBlue13's Avatar
BigBlue13
Old Mar 1, 2017 | 03:09 PM
  #60
Rancho Suspension
Former Vendor
Correct, the $100 rebate.
I'm solely looking at 4 9000xl shocks and the stabilizer kit. So I would just get the $100 rebate then correct? Nothing for the stabilizer kit?
