Ignition questions
Old Feb 14, 2017 | 03:43 PM
TheProfessorofTOOL's Avatar
TheProfessorofTOOL
Originally Posted by Tedster9
Have to work around the EGR as someone else noted. The engine was originally tuned for that, the ignition curve for one thing. If it was deleted they probably had to back way off on the timing and now it may not run right. Not saying this is exactly the issue but that's the kind of thing to keep in mind at this point.
I'd never thought of that honestly. The egr is still under the carburetor, the manifolds just have no egr tubes on them. I'll have to look into that more.
Old Feb 14, 2017 | 03:44 PM
TheProfessorofTOOL
Keep it mild and reliable. If it doesn't have a ton of miles on it since the last rebuild, I would use the cam that is in it.
After doing some reading it seems that gt40 heads aren't that great on a 351w. I want reliable low end torque.
JWray707
13
Feb 23, 2019 06:03 PM
compman
Aug 3, 2008 06:21 PM
kennyf100
Apr 9, 2007 06:45 AM
slider00200
Jul 15, 2005 06:19 AM
jan2
Feb 15, 2001 10:25 PM
