79,66 BODY
Old Feb 9, 2017 | 03:19 PM
swoosh1958's Avatar
swoosh1958
79,66 BODY
Hi guys, I have a 1966 F100 bolted on a 1979 F150 4x4 chassis. Can anyone tell me if I do a flip rear spring hanger, how much does the hanger have to move forward to get the correct angle? How much will it move the axle forward? How much lift can I expect? My bed is centered on the wheel now, but the bed needs to move forward about 1.5".
Old Feb 9, 2017 | 05:02 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Do you see the blue line with User CP, Albums, FAQ? See the SEARCH on that line?
It has a drop down search menu arrow, go to the "Advanced Search" option, top left side (search block) type in there what you are looking for and then go to the lower right column and highlight 73-79 forum. Select it and then you will have a detailed search just in the 73-79 forums.
From what I have read and understand, a stock shackle flip can get you 1.5 lift. You reuse the 2 front holes and then drill 2 new fwd of that.
Here is a FTE thread on it using Rough Stuff product. https://www.ford-trucks.com/forums/1...tallation.html
77&79F250's Avatar
77&79F250
Old Feb 12, 2017 | 06:58 PM
swoosh1958's Avatar
swoosh1958
Thanks guys for the links.
JBMorrey
Nov 7, 2017 07:24 PM
DaisyF150
Jul 19, 2017 11:56 PM
dthut
Apr 3, 2016 01:16 PM
1978fordshort
Dec 8, 2013 10:46 AM
