General Automotive Discussion
Key security
Old Feb 9, 2017 | 10:59 AM
83FordMan2012's Avatar
83FordMan2012
Key security
Hi I have a 1998 Ford Expedition XLT. I changed out the steering column, and now it won't start. I even changed out the lock cylinders. As soon as I turn on the key the theft light is blinking fast and the truck won't start. Any suggestions on fixing this problem.
Old Feb 10, 2017 | 07:08 PM
Ford_Six's Avatar
Ford_Six
You need to use your original key and tumbler. That's the code the computer is looking for.
Old Feb 10, 2017 | 07:12 PM
83FordMan2012
I am using the original it started at first than stalled and hasn't started since
Old Feb 10, 2017 | 07:15 PM
83FordMan2012
I know that this sounds a little like a mechanic malfunction. Does it make a difference that the wire that comes from the shifter wasn't connected when I first started it with the new column?
Old Feb 11, 2017 | 07:18 PM
projectSHO89's Avatar
projectSHO89
The PATS transceiver on the replacement column either isn't connected properly or is defective. If the engine started normally with the original column, then swap BOTH the tumbler (so the key will turn) and the transceiver from the old column to the new and it should work with the old key(s).
The PATS transceiver is that ring around the lock cylinder. It's job is to read the key when the switch is first turned from OFF to run. It's usually held on with a single screw.
Old Feb 11, 2017 | 07:50 PM
83FordMan2012
What if I was to purchase a new locks cylinder with keys. Would that work, because the key and tumbler from the column that is in the truck is now in my 98' Lincoln Navigator which is my daily driver now while I get the Expy ready to sell
Old Feb 11, 2017 | 08:49 PM
Ford_Six's Avatar
Ford_Six
It'll need to be programmed at Ford, so a tow and $100 charge most likely.
Jdolson22
Aug 22, 2017 12:07 PM
dave47111
Jun 14, 2014 11:06 AM
modfan
Escape & Escape Hybrid
Nov 25, 2010 11:34 PM
cobrarep
Aug 27, 2008 10:23 PM
cobrarep
Aug 26, 2008 10:56 AM
