Need help again
Old Feb 8, 2017 | 06:34 AM
McBusiness11's Avatar
McBusiness11
Need help again
I have a 2005 6.0. I just got done doing the HPOP seals, injector o-rings, stand pipes and dummy plugs. I have drove the truck 600 miles since the work with no problems other than a wiring issue I got fixed through help from this forum.
I'm sitting on the side of the road waiting for help to get here. I was driving at highway speeds, and all of a sudden I lost power and got a shake when trying to accelerate. I pulled over and turned it off, and when I went to restart it I got nothing at first, then it went to what seemed like a partial crank followed by a thud. So I'm thinking I just hydro locked it. I waited a few mins and tried again, and it started but had a few knocks for 15 seconds or so, then it ran rough with smoke pouring out of the exhaust (grey then turned kinda white). I the only codes I have are for the egr which I've had unplugged for a long time, and a glow plug code, but when I started it back up, I had no codes. I'm baffled. I did notice I have oil on my oil filter housing at the cap, a little oil had slung on to my wire harness and my intake. I don't even know where to begin!
Old Feb 8, 2017 | 07:00 AM
navistarnut's Avatar
navistarnut
Find the source of the oil leak for starters. Not to be a pessimist but white smoke is never a good thing unless it's 0* and only condensate burning off.
Old Feb 8, 2017 | 09:08 AM
McBusiness11
I ficed my oil leak problem. I drove it 300+ miles since then. I believe it's hydrolocked. The way it sounds when I try to start it, that's gotta be it. But I don't know the reason for that.
Old Feb 8, 2017 | 09:29 AM
TooManyToys.'s Avatar
TooManyToys.
Was that a new glow plug code?
Were you missing any nuts or small bolts when you were reassembling the top of the motor?
I'd start by pulling the glow plug with the code and see if cranking the motor over pushes out fuel or not. If not, all glow plugs come out and the motor gets cranked over to find which cylinder has the hydrolock. Then remove the injector from that cylinder and examine the tip for a crack or missing section. I would then use a bore scope to look into that cylinder and see if there is damage to the piston and the cylinder wall.
Old Feb 8, 2017 | 10:08 AM
navistarnut
So to clarify you have driven it 300 miles since the trouble began with shut down? Or you fixed the oil leak first and now this happened?
Old Feb 8, 2017 | 10:18 AM
McBusiness11
I repaired the HPO leak I had, now this has happened. I'm pretty positive it's hydro locked. I turn the key, the starter engages the motor, but a fraction of a turn into it, there's a thud and the starter just stops. I've watched a few videos on hydro locked engines, but I've never seen one that wouldn't start. I was blowing white smoke this morning, so I'm assuming the egr cooler has dumped coolant. That being said, when this happened it did fire up once after the power loss and I heard a knock from the driver side for just a few seconds. It was running really rough but would smooth out when I gave it gas, and smoke was BILLOWING out the whole time I had it running, which wasn't very long (45 seconds maybe). I had some smoking issues before the HPO leak, and the 300 miles I drove since then, I didn't see much smoke at all. Maybe on startup but not much at all until this morning. To me, it sounds like the egr cooler was going bad before and just went out this morning. But I would LOVE some other opinions. This truck has given me hell for 2 months now!
Old Feb 8, 2017 | 11:40 AM
TooManyToys.
It could be a cooler, I'm just fixated on injectors where excessive fuel will cause white smoke.
Old Feb 8, 2017 | 11:51 AM
McBusiness11
I thought white smoke was more likely coolant. Grey was fuel. Is that backwards?
Old Feb 8, 2017 | 12:08 PM
87crewdually's Avatar
87crewdually
If it's that bad stick your nose in the tail pipe. You really need to pull passenger side glow plugs starting with 5 & 7 and see what you get.
Old Feb 8, 2017 | 02:29 PM
McBusiness11
The noise I heard was from the driver side. Are the passenger side more likely to fail?
Old Feb 8, 2017 | 02:46 PM
brandonrr's Avatar
brandonrr
It sounds like you either have an injector sticking open, dumping fuel in the cylinder or your egr cooler is leaking.
you can rule out egr by pulling the valve and checking for moisture.
Does the exhaust smell like fuel or coolant?
On a side note, please plug your egr valve back in. Your clutch fan will not operate properly with it unlugged. That trick works on the early 6.7 cummins, but not any of the egr-equipped powerstrokes. If you want to keep the egr in place without it being used, use a sct tuner. Even with the "canned tunes" it comes with, there is an option to eliminate egr use. If you are afraid of adding power, you can choose trans only tuning and turn the egr off.
Old Feb 8, 2017 | 02:48 PM
87crewdually
If you have no idea what has it hydrolocked (fuel or coolant) then I'd do like I posted. Reason being is if the EGR cooler cracked it will flow coolant to the passenger side.
Old Feb 8, 2017 | 02:59 PM
brandonrr's Avatar
brandonrr
good point. In that case, it's probably fuel.
OP, if you have a severly leaking or stuck open injector, it could easily torch the piston. The hydrolocking could also bend a rod. Either way, if you keep running the truck as it is, you will likely turn a minor-ish repair into needing a new engine.
87crewdually has the right idea. Pull the glow plugs and it should be pretty easy to tell what comes out. Be careful though. Whatever is in there is going to come out with a lot of force when you crank it with the plugs out.
Old Feb 8, 2017 | 03:55 PM
navistarnut
Makes no difference plugged or unplugged on early builds. Trips a code yes, but does not cause the fan to not operate. I know of three early builds, one ours, all deleted with no EGR and fan runs normally.
Old Feb 9, 2017 | 07:27 AM
53jimc's Avatar
53jimc
Careful trying to start/run if it's hydrolocked, that can cause big problems.
Mine did that last Feb, started running like crap, white smoke everywhere. My son was driving it so he parked it and I had it towed home.
When you try to start it once it gets to the hydrolocked cylinder it will struggle to turn past it. If you keep trying, it will fill up with fuel and it will stop turning. If it does start you could damage some very expensive stuff.
I took out all of the glow plugs then cranked it over and the hydrolocked cylinder was obvious. BE CAREFUL when you do this or you'll take a bath in diesel fuel.
Once you find the offending cylinder(s), replace the injector(s).
I was losing coolant also, so while I was at it I replaced the EGR cooler and oil cooler, but that's a different story.
Good Luck.
