When should I shift gears?
Old Feb 6, 2017 | 07:52 PM
DieselCamper's Avatar
DieselCamper
This is my first manual vehicle, I'm at a loss of when to shift for the best MPG possible and not lugging motor.
Its a 1990 F150 RCSB with an M5OD, a 302 and 3.55 gears. Is there a way to decode when I should shift or anything like that?
Old Feb 6, 2017 | 08:37 PM
Conanski's Avatar
Conanski
For best mpg shift at a relatively low rpm like 2500 and use moderate throttle, and don't use the engine to slow down when coming to a stop like all the ricers do everywhere all the time, shift into neutral and use the brakes.
Old Feb 6, 2017 | 08:45 PM
DieselCamper
I try to do that. I hate downshifting.
Old Feb 6, 2017 | 09:16 PM
GoinBoarding's Avatar
GoinBoarding
I'd shift it just after you scatter the crank, for an excuse to drop in a 351W ;-)
Kidding of course. I have minimal experience driving standard trans so feel free to ignore me, haha.
Old Feb 6, 2017 | 09:17 PM
FoxFord33's Avatar
FoxFord33
You can calculate the power band, but it's easier to feel it. You can do this by accelerating without flooring it and there is a point where the acceleration slows. To keep mpg up, shift right when you reach the point of diminishing return. Drive it enough, and you will be one with the machine. You'll be able to feel when to shift.
Or, calculate by transmission gears and rear gears and let the tach be your boss. Either way, the shift points will be pretty similar.
Old Feb 6, 2017 | 09:20 PM
DieselCamper
No 351W for me! This thing dies, it's a 300 or bust.
Is there a program to do this? I have 0 idea how it works haha.
Old Feb 6, 2017 | 09:28 PM
FoxFord33's Avatar
FoxFord33
Here's how one guy explains it:
Optimal Shift Point
He talks about using dyno-type information to calculate, but if you have a tach you can use that.
Old Feb 6, 2017 | 09:36 PM
DieselCamper
Optimal Shift Point
Guess I have to go dyno my 302 😂😁
Freightrain's Avatar
Freightrain
Ok, when does downshifting ruin gas mileage?
I downshift(gee, does that make me a ricer? Ok, whatever ), as it saves wear and tear on brakes around town. You aren't on the gas pedal so no fuel is being put into the engine. So NO affect on fuel mileage. It doesn't wear out the clutch either, if don't correctly.
Driving a stick is not difficult and if you LISTEN to the engine it tells you want it needs. Not all trucks come with a tach, so you can't rely on that every time.
Old Feb 6, 2017 | 10:00 PM
wtroger's Avatar
wtroger
You want to shift when going into the next gear doesn't cause the engine to lug.
Old Feb 7, 2017 | 05:47 AM
Mudsport96's Avatar
Mudsport96
​​​​​​Wish I would have seen this sooner, I would have paid attention to where I shift when I drove to work this morning. If I remember, I'll watch when I go home today and post up. Same basic drive line as you so it should be close
Old Feb 7, 2017 | 08:01 AM
Scndsin's Avatar
Scndsin
Wow.
Someone from Montana who hasn't driven a stick enough to naturally know the feel of manual shift points...
At any rate, opinions, like rectal orifices, are universal. (Some stink more/less than others, but most everyone prefers their own )
You need to learn how to down-shift. Particularly in an emergency situation. Its not just for ricers. It helps you have the power band in the proper place should and if you need it.
If you want to know the exact place to shift, buy & install a vacuum gauge.
Good luck & congrats on new purchase.
Old Feb 7, 2017 | 08:03 AM
Conanski's Avatar
Conanski
Fueling is dependent on rpm so yes it's still getting more fuel than an idling engine. Any yes it will put more wear on the clutch unless you "do it right" and speed match the engine which again will cost more fuel. And what's easier and less expensive to replace.. brake pads or the clutch?
Old Feb 7, 2017 | 08:27 AM
jas88's Avatar
jas88
Not true on Ford EFI. The injectors are shut down on decel.
A rule of thumb for best shift point for mileage is to shift at or near the torque peak RPM. On your 302 that is 2400 RPM.
Old Feb 7, 2017 | 08:55 AM
DieselCamper
Perfect, stupid me thought it was 2500, haha
Brake pads.
Originally Posted by Scndsin
Wow.
I'm actually from the awful, terrible state of "Missouruh"
